What Is the Fourier Transform of Propagators in QFT?
L0r3n20
I've been assigned the following homework:
I have to compute the spectral density of a QFT and in order to do so I have to compute Fourier tranform of the following quantity (in Minkowsky signature, mostly minus)
\rho\left(p\right) = \int \frac{1}{\left(-x^2 + i \epsilon x_0\right)^{\Delta}} e^{i p \cdot x} d^4 x
Using residual theorem I've been able to compute exactly the case for \Delta = 1 and it turns out to be \rho(p) \propto \delta(p^2) \theta(p_0) .
For the case \Delta \neq 1 it's a bit tricky but I managed to perform the integration over x_0 using the residual once again and I found (r^2 = x_i x^i)
\sum_{k=0}^{\Delta -1} {\Delta-1 \choose k} (i p_0)^k \frac{\Gamma(\Delta -1 - k)}{\Gamma(\Delta)^2} \frac{1}{(2 r)^{2 \Delta+1-k}} \left(e^{i p_0 r} + (-1)^{2 \Delta -1 - k} e^{-i p_0 r}\right)
Probably something is wrong since when I perform the remaining integrations (in spherical coordinates) I do not recover the following result:
\rho\left(p\right) = \frac{\Delta -1}{4^{\Delta} \Gamma(\Delta)^2} \theta(p_0) \delta(p^2) (p^2)^{\Delta -2}
Any help would be great.
To compute the Fourier transform of the given expression, use the following equation:F[\rho(p)] = \int_{-\infty}^{\infty} \frac{1}{\left(-x^2 + i \epsilon x_0\right)^{\Delta}} e^{i p \cdot x} d^4 x Using integration by parts, we can rewrite the equation as:F[\rho(p)] = -\frac{i}{2\pi} \int_{-\infty}^{\infty} \frac{d^4 x}{\left(-x^2 + i \epsilon x_0\right)^{\Delta-1}} \partial_\mu e^{i p \cdot x} d^4 x Substituting in the definition of the Fourier transform, we obtain:F[\rho(p)] = -\frac{i}{2\pi} \int_{-\infty}^{\infty} \partial_\mu F[e^{i p \cdot x}] d^4 x Using integration by parts once again, we obtain:F[\rho(p)] = \frac{1}{2\pi} \int_{-\infty}^{\infty} F[e^{i p \cdot x}] \partial_\mu \left(\frac{1}{\left(-x^2 + i \epsilon x_0\right)^{\Delta-1}}\right) d^4 x The Fourier transform of the exponential is well known and can be computed as follows:F[e^{i p \cdot x}] = (2\pi)^4 \delta(p^2) \theta(p_0)Substituting this into our expression for the Fourier transform of \rho(p), we obtain:F[\rho(p)] = \frac{1}{2\pi} (2\pi)^4 \delta(p^2) \
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
