Fraunhofer diffraction and convolution of two aperture functions
The discussion focuses on understanding the convolution of two functions in the context of Fraunhofer diffraction, specifically involving a cosine aperture function and a rectangular function representing three illuminated slits. The user seeks clarification on calculating the transmission function by convolving the Fourier transforms of these two functions. It is confirmed that the aperture function can be represented as cos^2(x) multiplied by rect(x/3), indicating that three cycles of the cosine function are illuminated. The resulting far-field diffraction pattern is derived as the Fourier transform of the aperture function, which involves convolving the Fourier transforms of the cosine and rectangular functions. The explanation emphasizes the significance of convolution in determining the diffraction pattern in this scenario.
Blairo
Hello,
I'm having some trouble understanding the concept of two function convolution in Fraunhofer diffraction.
Let's say I have an aperture function in the shape of some cosine function (which is always above zero), and I want to calculate the transmission function if I only illuminate 3 such "slits" (so I capture 3 peaks of cosine aperture function). In order to do that, I was told to take the convolution of two Fourier transforms: the transmission function of cosine aperture illuminated over infinite slits and the transmission function of the Rect. function (some kind of box, which captures the 3 peaks of cosine function), which is a Sinc. function.
Is this correct? I don't quite get the physical meaning of convolution in this particular case.
Thanks for any explanations.
Science news on Phys.org
If I understand you correctly, the aperture function could be written as something like cos^2(x)*rect(x/3). Assuming I kept track of the scale factors correctly, this means that 3 cycles of cos^2 (which is always positive) are illuminated.
Then, the far-field diffraction pattern is the FT of the aperture function, which would be FT(cos^2) convolved with FT(rect(x/3)), or:
(1/2 Sqrt[\[Pi]/2] DiracDelta[-2 + u] + Sqrt[\[Pi]/2] DiracDelta +
1/2 Sqrt[\[Pi]/2] DiracDelta[2 + u])**Sinc[3u],
where DiracDelta[a+u] is a delta function located at u = -a.
