Free body diagram, normal force, static friction
The discussion focuses on calculating the free body diagram, normal force, and static friction for a roller coaster cart on a 23-degree incline with a mass of 363 kg. The normal force is calculated using the formula Fnormal = mg cos(θ), resulting in 3277.95 N. The coefficient of static friction is determined to be 0.42 using the equation coefficient of static friction = tan(θ), leading to a maximum static friction value of 1376.74 N. Participants clarify the absence of a pulling force and emphasize the importance of understanding forces acting on the cart as it begins its descent.
  • Understanding of free body diagrams
  • Knowledge of Newton's laws of motion
  • Familiarity with trigonometric functions in physics
  • Basic principles of static friction
  • Study the derivation of normal force in inclined planes
  • Learn about the dynamics of roller coasters and forces in motion
  • Explore the relationship between static friction and normal force
  • Investigate the effects of acceleration on forces in inclined systems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of free body diagrams and friction calculations in real-world applications.
cafe au lait
There is a roller coaster cart with passengers sitting on the top of a 23 degree incline. The ride is about to start. The combined mass of the cart and passengers is 363kg.
a) What would the free body diagram look like?
b) How do you solve for normal force?
c) How do you solve for maximum value of static friction AND coefficient of static friction?
m=363kg
g=9.81m/s2
theta=23 degrees
Fnormal=mg*cos(theta)
coefficient of static friction=tan(theta)
maximum value of static friction=coefficient of static friction*Fnormal
a) Fg arrow pointing straight down, Fnormal arrow pointing perpendicular to the cart, Ffriction arrow on right or left side of cart and Fpull arrow on the other.
b) Fnormal=(363kg)(9.81m/s2)cos(23degrees)=3277.95N
c) coefficient of static friction=tan(23degrees)=0.42
maximum value of static friction=0.42(3277.95N)=1376.74N
I'm not very confident in my physics abilities so I was hoping someone could reassure me that I did this right. :) Thanks in advance!
welcome to pf!
hi cafe au lait! welcome to pf! :smile:
(have a theta: θ and a mu: µ and a degree: ° :wink:)
fine, except a roller-coaster doesn't have an Fpull … it coasts! :wink:
fine … there's no acceleration in the normal direction, so FN = mg cos23°
i think you're not meant to do it that way, but by taking components along the slope …
use an equation like FN = mg cos23° to get Ffr, and then calculate µ from Ffr and FN :smile:
Hi thanks for your help!
A) Okay, so how about I replace Fpull with Fpush? My thinking behind that is a force (push) holds the cart at the top of the track until it's time to let go...
B) If there was acceleration, would that change the equation to FN=ma cos θ?
C) Ffr=(363kg)(9.81m/s2) cos23°=3277.95N
µ=Ffr/FN
µ=3277.95N/3277.95N=1
Uh that doesn't look right :(
hi cafe au lait! :smile:
if the brake is on, then you're correct … there must be either a push or pull force
but i think that when the question says "The ride is about to start", it means that the brake has just been taken off
(otherwise it'd say something like "The ride has not started yet")
that doesn't make sense … how can there be a normal acceleration if the rollercoaster stays on the track? :confused:
i said an equation like that, not that actual equation! :rolleyes:
