Free fall distance with non-constant g
  • Thread starter Thread starter DavidTheGreat
    Fall Free fall
The discussion focuses on calculating the distance of free fall for an object with zero tangential velocity and a given radial velocity, specifically in the context of non-constant gravitational acceleration at orbital heights. The user is attempting to solve a second-order differential equation derived from gravitational forces but is struggling with the integration and application of energy conservation principles. Suggestions include using numerical methods for complex calculations and applying energy conservation to determine the object's motion after being dropped from a height. The conversation emphasizes the importance of understanding the initial conditions and the resulting equations to accurately predict the object's trajectory and fall time. Ultimately, the discussion highlights the complexities involved in solving such gravitational problems analytically versus numerically.
DavidTheGreat
<Moderator's note: Moved from elsewhere and therefore no template.>
I'm trying to calculate the distance of free fall for an object with zero tangential velocity but a given radial velocity at a given height over a given period of time. This calculation cannot assume that g is constant as it deals with orbital heights. These calculations are needed for an orbital ring that I'm designing. Here is my working out so far.
1.) F=ma
2.) F=GMm/R^2
Sub 1.) into 2.)
ma=GMm/R^2
a=GM/R^2
v=da/dt
v=d/dt(GM/R^2)
v=GM d/dt(1/R^2)
R=dv/dt
R=GM d^2/dt^2(1/R^2)
I can't figure out how to solve this second order differential equation. Is there a better way of doing it/where did I go wrong?
1.) F=ma
2.) F=GMm/R^2
Sub 1.) into 2.)
ma=GMm/R^2
a=GM/R^2
v=da/dt
v=d/dt(GM/R^2)
v=GM d/dt(1/R^2)
R=dv/dt
## a=\frac{dv}{dt} ##. Also ## v=\frac{dR}{dt} ##. From these two equations, you should be able to solve for an expression for the acceleration ## a ##.
Thank you. So I tried again and got stuck again.
I don't know how R varies in time so I can't solve the integral.
Energy considerations do tell you that ## v=\frac{dR}{dt}=-\sqrt{\frac{2GM}{R}} ## if you assume the object started at ## R=+\infty ## with ## v=0 ##. The form ## \sqrt{R} \, dR=C \, dt ## can be readily solved for ## R=R(t) ## by integrating both sides of the equation.
Thanks I tried to put the energy considerations in but I think I went wrong again. The final solution looks too ugly. Where did I go wrong?
Sorry the image was too small here it is again.
At ## t=0 ##, you need to use ## R=R_o ##. Also the minus sign for ## v ## goes outside of the square root. In the homework section, the Homework Helpers are not allowed to supply complete answers, but this is slightly different from a homework problem in that it doesn't seem to have a final goal. Anyway, the expression you get upon integrating is ## R(t)=(-(\frac{3}{2})( \sqrt{2GM}) t+R_o^{3/2})^{2/3} ##. Even though the velocity ## v \rightarrow -\infty ## as ## R \rightarrow 0 ##, you can still solve for the time ## t ## it will take to reach ## R=0 ## from the position ## R_o ##. Suggestion: Try setting ## R(t)=0 ## and see what you get.
For total energy ##E \neq 0## we have
$$\frac{1}{2} m v^2 - \frac{K}{r} = E,$$
so
$$v = \sqrt{\frac{2}{m}} \sqrt{E+\frac{K}{r}}.$$
The differential equation
$$\frac{dr}{dt} = \sqrt{\frac{2}{m}} \sqrt{E+\frac{K}{r}}$$
can be solved implicitly (that is, in the form ##F(r) = t## with a known ##F(r)##. However, if you want an explicit solution of the form ##r = f(t)##, you will need to solve the equation ##F(r)=t## numerically (in the case ##E \neq 0##). Or, you can make a table of ##r,t## values, then just reverse the columns to have a table of ##t,r## values.
Maybe I should be more specific. What I'm trying to solve for is the same as the following situation. Imagine that you are traveling at 1km/s up a geostationary space elevator and when you reach an altitude of 1000km you drop a soft drink can out of the air lock with minimal tangential velocity. At first it is going to go up because of your momentum but eventually Earth's gravity will pull it down. How long until it comes back down to the 1000km mark?
Suggestion is to start a new thread with this problem, and use the homework template, and the Physics Forums rules do require that you make an effort to try to solve it and try to work to the solution.
If you have specific numbers like that you can call upon a numerical differential equation solver to do the work. There is nothing "wrong" with using reliable numerical methods when the problem is too difficult to allow an analytical solution.
Alternatively, you could apply the method I posted in #8, using
$$ \frac{dr}{dt} = \sqrt{\frac{2}{m}} \sqrt{E+\frac{K}{r}} $$
on the upward part and
$$ \frac{dr}{dt} = -\sqrt{\frac{2}{m}} \sqrt{E+\frac{K}{r}}$$
on the downward part. That would give you two implicit solutions of the form ##t = F_1(r)## on the upward part and ##t = F_2(r)## on the downward part. The top of the path (end of upward part) would be where ##dt/dt = 0##, so where ##K/r = -E## (with ##E < 0## given by the initial conditions). The implicit fordm of solution is perfectly suited to your problem because it gives time directly as a function of altitude.
You can attack this in two parts:
First, by energy conservation, work out how high your cup travels above 1000km before it starts to fall back.
Then you can solve for the time it takes to fall from a point at rest from that altitude to 1000 km (there is an implicit formula for this), keeping in mind that the fall time and "climb" times will be equal.
The resulting equation will be tricky to integrate. Some type of substitution will help.
$$\frac{dr}{dt} = \sqrt{\frac{2}{m}} \sqrt{\frac{Er + K}{r}}$$
$$dt = \sqrt{\frac{m}{2}} \ \ \sqrt{\frac{r}{Er + K}} \ \ dr$$
Yes, the integrations are tricky, but are entirely standard---the types of problems students get assigned as homework in Calculus courses. Or, you can submit it to a package like Wolfram Alpha.
Did this ever get solved. There are prior threads about the time for two objects to collide due to gravity, but with zero initial velocity. The initial velocity adds another component. Also for an alternative approach, a = dv/dt =GM/(r^2) could also be handled via chain rule, a = (dv/dr) (dr/dt) = v dv/dr = GM/(r^2), which result in a similar equation for v(r, v0).
Starting with an initial velocity can be handled by using energy conservation to simplify to a zero initial velocity. In the upward moving cup scenario, you solve for how high the cup will climb before reaching the apex, and then solve for the apex to starting position fall time.
If you wanted to work out the time to fall from one height(h1) to another(h2) when you have an initial velocity of v, you would first work out from what height(h3) it would have taken to reach a speed of v at the first height, if it started its fall from h3 at rest. Then you can take the difference between the times needed to fall starting at rest from h3 to h1 and from h3 to h2, to find the time needed to fall from h1 to h2.
I was thinking about the case where the initial velocity is inwards (downwards), and the total energy U+K = E > 0 , similar to an escape velocity situation in reverse.
