B How Do Proper Acceleration and Gravity Affect Time Dilation in Free Fall Orbits?
name123
I had been informed that for objects in free fall orbit no proper acceleration would be measured.
https://www.physicsforums.com/threads/stationary-frames-of-reference.899195/page-2#post-5658771
But I also understood it that for objects in free fall orbit gravity time dilation would be observed.
https://www.physicsforums.com/threa...vitational-time-dilation.563173/#post-3685830 .
So I am not sure how proper acceleration and gravity are equivalent, as in the example given in the last thread referenced, each time B comes back to A the difference between the clocks would show an affect of gravity, and the affect could be dismissed as being an affect of proper acceleration, as no proper acceleration would have been measured by A or B. So can someone explain why proper acceleration and gravity are equivalent in this example?
With two satellites, going at the same velocity, in free fall orbit around a massive body at different altitudes for a few thousand years, as I understand it the clock on the one much closer to the massive body would run slower than the one in a higher free fall orbit so that if they were both quickly brought together and compared the clock that was in lower orbit would have measured less time passing.
Would the comparison be significantly different if one of the satellites was in free fall orbit at a much greater velocity than the other? If so, what type of difference would it make compared to if they were going at the same velocity? If the bringing the together (presumably a constant affect) were to influence the outcome, perhaps it could be explained how the difference (if there would be one) would vary dependent on how long they had been orbiting for, once the gravitational affect had been taken into account.
By those objects.
As seen by others.
Different reference frames. An outside observer can tell if you fall towards a black hole or sit in a rocket, e.g. by detecting the black hole or the rocket.
For orbits driven by gravity, orbital velocity and gravitational potential energy (averaged over an orbit) are linked, you cannot change them individually.
They are only equivalent locally. The scenarios you describe are non local.
If you restrict yourself to local scenarios then the equivalence principle applies. In fact, this local equivalence can be used to derive the gravitational time dilation e.g. for the Pound Rebka experiment.
mfb said:
By those objects.
Yes neither of the objects involved would measure proper acceleration. And from what I understood from what was written in the link I supplied ( https://www.physicsforums.com/threads/stationary-frames-of-reference.899195/page-2#post-5658771 ):
"Proper acceleration, the kind that an accelerometer measures and that is the same no matter what coordinate system I choose, happens or not according to whether the object is in free fall or not. Freefall paths through flat spacetime appear in space like the straight lines of Euclidean geometry; freefall paths through curved spacetime do not. eiether way they are freefall paths and there is no proper acceleration."
The measurement of proper acceleration is coordinate system independent. Were you in agreement that in no coordinate system would those object be considered to be undergoing proper acceleration?
mfb said:
As seen by others.
I am not sure what you meant by "as seen by others". In the link I supplied ( https://www.physicsforums.com/threa...vitational-time-dilation.563173/#post-3685830 ) I had assumed B performs the orbit, and comes back into the same rest frame as A to compare clocks, similar to the Hafele-Keating experiment. The result of that I had assumed was reference frame independent. Were you in disagreement that for objects in free fall orbit the affects of gravity time would be observed even though all coordinate systems could agree that there was no proper acceleration measured on board?
I assume your comment about orbits driven by gravity, orbital velocity and gravitational potential energy (averaged over an orbit) are linked, you cannot change them individually. Had to do with where I wrote:
I am not sure what need to be able to change anyone of them individually. The change of the velocity could imply a change in orbit, but presumably that does not prohibit the calculation of what amount of time dilation would have been expected due to the gravitation effect (which I think is known as gravitational time dilation) and how much was due to the relative velocity differences (which I think is known as kinematic time dilation), and what as I understand it they did in the Hafele–Keating experiment. And therefore the difference in the proportion of the time dilation due to gravitational time dilation and the proportion due to kinematic time dilation could be calculated for example.
Sorry I am not quite clear on what you mean by "locally". I assume it is not connected to the principle of locality vs "spooky action at a distance". Is it the same as being in the same frame of reference?
It means close enough in space and time so that tidal effects are negligible. I.e. a uniform gravitational field.
They aren't. Gravity doesn't cause proper acceleration. The equivalence is between local frames of reference, which undergo the same proper acceleration. For example:
- Frame in free fall near Earth is locally equivalent to frame floating in deep space (0g proper acceleration).
- Frame at rest to Earth's surface is locally equivalent to frame of an accelerating rocket in deep space (both 1g proper acceleration).
Proper acceleration doesn't affect proper time:
https://en.wikipedia.org/wiki/Clock_hypothesis
Thanks I think I get it now (undergoing the same g proper acceleration).
Ok thanks.
With regards to:
Have you got any answer, taking into account:
The reason I am asking is that if the change is in a certain direction, then how were the velocities relative, could you not tell from the end clock measurement which had been traveling faster?
Proper acceleration and gravity are equivalent locally, in a small enough region of space-time. So if you consider a small orbiting object, say the space-station MIR, and we assume the space station isn't rotating, to the first order you won't have any "gravity" inside the space station. We will say the astronauts inside the space station are in "free fall", you've probably seen the videos.
Note that you'll still see second order effects (which would be called tidal forces) - the larger the space station, the more important these tidal accelerations will become. Also, the longer you observe an object, the more important these effects become.
The tidal forces are small, but over time they will have noticeable effects, so ignoring them completely is simply wrong. Suppose, for instance, that we had a (non-rotating) space station in Earth orbit, as follows
...............A
E
...............B
E is the Earth, we are looking at a side view so that A and B have a velocity that's out of the plane of the paper, i.e. if the paper is in the x-y plane, the velocity of A and B is in the z direction.
In such a situation, if there are no external forces acting on A and B, they will both follow perfectly circular orbits. These circular orbits will intersect twice every orbital period. This is noticably different from how A and B would act if they were in an inertial frame.
This does not show that the principle of equivalence is fundamentally wrong, it does show that it's purely a local approximation, valid to the first order over a short enough time period. And that if we attempt to apply it to an entire orbital period (or some large fraction thereof), we have misused it. While there is no "gravity" inside the space station, in Newtonian theory we say there are tidal forces. In General Relativity we might use a slightly different language (but tidal forces will do, and it will be less distracting than using the exact description that GR uses).
On a related note, it's possible you've fallen into the trap thinking that it's "acceleration" that explains time dilation, and have a fundamentally non-relativistic view of the structure of time based on the absolute time idea we've inhereted from Newtonian physics.
The simple way of describing the facts is this. Two objects, each of which caries their own clock, will in general have different clock readings if they take different paths through space-time. There is no logical reason to assume they won't - the only reason to think they would is due to the fact that it works that way in classical, Newtonian physics. For a worthwhile analogy, if we have two cars with odometers, and they drive along different routes and rejoin each other, we don't even expect the odometer readings to be the same when they re-unite. IT's logically consistent for objects to have clocks that read differently when they move differtrently, just as it's logically consistent that odometers won't read the same for cars driving different routes. It's just not something that we are used to. If we use the block universe interpretation (not required, but helpful), we can even view clocks as being a kind of space-time "odometer".
Over long time periods, in the full GR case one can draw no conclusion over which clock will read more and which clock will read less when they re-unite based solely on their acceleration profiles. To use the orbital example, suppose that one clock is orbiting the Earth in a circular orbit. They other clock moves only in a radial direction, it moves outwards in such a manner that it rejoins the orbiting clock after one orbit. Neither clock experiences any proper acceleration, but they will have different time readings when the re-unite. The clock moving outwards winds up having the longest elapsed proper time.
At the risk of confusion, I'll add that there is a principle that says that if all possible clocks take different paths through space-time and re-unite after some finite time, there will be at least one clock that has the maxium time reading, an upper bound. We can say that this clock will be a clock that experiences no proper acceleration, that this is a necessary condition.. Having no proper acceleration is a necessary condition for having the maximum proper time, but it's not sufficient. The previous example shows an case where we have two clocks, neither one of which experiences any proper acceleration, but yet both read different times when they re-unite, which serves as a direct counter-example.
Over short enough time periods in GR, or in the case of flat and simply connected pace-time of special relativity, it turns out that the clock that does not accelerate has the largest reading, that in these cases the zero acceleration is sufficient as well as necessary for zero proper acceleration to imply maximal aging. Unfortunately, if we consider the more general case of GR over long time periods, we simply can't say this.
Likes Herman Trivilino
...............A
E
...............B
Thanks for the response. As I now understand it, acceleration does not affect time dilation, although the amount of curvature does, the greater the curvature the slower the clock ticks. So in the satellite example I gave where from the perspective of the mass there are two satellites, in free fall, orbiting the mass in circular orbits, one closer to the mass and one further away, and at different velocities (from the mass's perspective). Could you explain how the clock time difference would vary when they were compared after bringing them together, if they had been observed orbiting (post clock synchronisation) for millions of years?
Presumably the bringing them together would become less significant the longer they orbited, and the amount of time dilation due to curvature would be frame of reference independent, but what about the observed velocities from the mass being orbited's perspective? If the satellites were labelled A and B and the mass C then would the clock comparison figure be correctly calculated no matter which you considered at rest?
Also I am not quite clear how A or B could be considered at rest and not rotating, as while C (the mass) could be considered to orbit A or B, if it was so considered, would it not also need to be considered that it was rotating, for an explanation of why the same section of C was not always facing A (or B), and could it not be objectively measured that it was not rotating?
No. Curvature just means that simple SR rules about who ages more don't apply.
Are you suggesting that if the curvature in a scenario was increased it would not make a clock within the curvature that was increased slow?
No, in fact it can be the opposite. Consider a spherical shell of mass. The spacetime inside the shell is flat with no curvature, while the spacetime outside the shell is curved. A clock outside the shell (in the curved portion of spacetime) will be faster than one inside the shell.
Likes Buckethead
I did not realize it would be flat inside the shell. Does it show some distortion relative to totally undistorted spacetime (distant from any mass), such that if the spherical shell of mass disappeared there would be a change to the spacetime within the shell, else why would clocks go slower inside the shell if spacetime was undistorted compared to the outside in distant space far from the shell where the clocks would be going faster?
Also regarding the questions about the two satellites A and B orbiting mass C, could you help there:
1) Presumably the bringing them together would become less significant the longer they orbited, and the amount of time dilation due to curvature would be frame of reference independent, but what about the observed velocities from the mass being orbited's perspective? If the satellites were labelled A and B and the mass C then would the clock comparison figure be correctly calculated no matter which you considered at rest?
2) I am not quite clear how A or B could be considered at rest and not rotating, as while C (the mass) could be considered to orbit A or B, if it was so considered, would it not also need to be considered that it was rotating, for an explanation of why the same section of C was not always facing A (or B), and could it not be objectively measured that it was not rotating?
No, it is just flat spacetime. All local experiments will give the same result as the same local experiment performed infinitely far away.
The continuity equations forbid the shell of mass disappearing. However, you could posit that the shell of mass suddenly turns into a spherical shell of radiation moving outward at c. In that case there would be no change to the spacetime within the shell. As the radiation passed a region, it would transition from curved to flat, but regions that were already inside would be unaffected.
That is a nonlocal comparison. Nothing is happening to either clock. They are both functioning normally locally, but between them spacetime is curved.
Regarding A and B, I don't really want to read a whole other thread to answer a question. I would rather you ask a self contained question.
Dale said:
No, it is just flat spacetime. All local experiments will give the same result as the same local experiment performed infinitely far away...That is a nonlocal comparison. Nothing is happening to either clock. They are both functioning normally locally, but between them spacetime is curved.
Why are they (the clock in flat spacetime in distant space outside the shell and the clock in flat spacetime in flat spacetime inside the shell) not local (which I understand means that they under the same g) to each other ?
Consider satellites A and B, going at different velocities, in free fall orbit around a massive body C at different altitudes for a million years, then being brought together and the clocks on them compared. Presumably the bringing them together would become less significant the longer they orbited, and the amount of time dilation due to curvature would be frame of reference independent, but what about the observed velocities from the mass being orbited's perspective? If the satellites were labelled A and B and the mass C then would the clock comparison figure be correctly calculated no matter which you considered at rest?
Also regarding A, B and C being at rest, I am not quite clear how A or B could be considered at rest and not rotating, as while C (the mass) could be considered to orbit A or B, if it was so considered, would it not also need to be considered that it was rotating, for an explanation of why the same section of C was not always facing A (or B), and could it not be objectively measured that it was not rotating?
name123 said:
Why are they not local (which I understand means that they under the same g) to each other ?
Why guess what it means, instead of reading?
I had read where you had written
Had I misunderstood you?
It's what Dale wrote in post #6 that is relevant.
As Dale explains, "local" means nearby. How nearby it has to be depends on how strong tidal effects are and how carefully you measure (i.e. how small is "negligible"). "Distant", on the other hand means far away. Something far away is unlikely to be local. If you have curved space-time between two areas of flat space-time then the two areas of flat space-time are not local to one another. Curved space-time and tidal effects are the same thing.
Dale wrote:
So if the shell disappeared like that, then Dale said the space inside would be unaffected, and how much affect could the shell of had on the region of distant space? Both clocks would end up at 0g proper acceleration, but the one, that had been outside the shell, going faster than the other, and I wasn't clear why. Were you thinking the clocks would not be local once the shell had radiated away like Dale suggested?
You asked what "local" means. I answered. I offered nothing about what I think about the hypothetical clocks in this scenario.
You could apply the definition of "local" to try to decide for yourself whether two clocks separated by a large distance in flat space-time are "local" to one another.
Well you were suggesting that the that Dale gave was what was important. So given the situation described
name123 said:
...but the one, that had been outside the shell, going faster than the other
Only until the radiation from the destroyed shell has passed it.
Have you even read the post #6 which I referred you to?
Why would the passing of the radiation slow it?
Yes Dale stated that local meant in a unified gravitational field. Why would the whole region once the radiation had passed not be a unified 0g gravitational field?
What does "unified" mean?
Please re read the definition I gave previously: "Local means close enough in space and time so that tidal effects are negligible. I.e. a uniform gravitational field". Is the gravitational field uniform in the region containing both clocks? Are tidal effects negligible?
The energy distribution affects the gravitational potential and thus the clock rates between distant points.
  • #31
Sorry that should be "uniform"
  • #32
Would they not be once the radiation had passed the distant clock a million years before at c?
  • #33
Yes, but note that the metric will have a different form in these different charts. With a correct expression for the metric, all invariants will be correctly calculated.
  • #34
So considering just the distant clock
1) Before the shell had radiated (imagine it was a light year away)
2) A year after the radiated had passed it at c.
What energy distribution difference between 1 and 2 were you thinking would explain the affect?
  • #35
Gravitational time dilation is always between two separated clocks. With just one clock there is nothing to explain.
  • #36
These two clocks are not local:
These two clocks are local:
  • #37
The distribution of the energy in the shell
  • #38
Then consider both the clocks.
1) Clock 1 in the shell in flat spacetime before the shell had radiated, and Clock 2 a light year outside the shell
2) Clock 1 two years after the shell has radiated away, the space time flat as it was in scenario 1, Clock 2 a year after the radiation from the shell had passed it.
  • #39
So the gravitational energy causes the time dilation?
  • #40
If each had a ruler and a clock on board, when they were at rest together could they not all go by their own clock and ruler, and agree that their clocks and rulers were metrically equivalent?
Could you explain this please?
  • #41
Also energy due to "stuff" like matter or light or whatever.
  • #43
Yes, completely.
The question is ambiguous. I cannot tell if you are asking about proper rotation or coordinate rotation.
  • #44
Proper rotation assuming that it what causes the proper acceleration that can be measured.
  • #45
Whether or not a given object is undergoing proper rotation is an invariant. It does not depend on the coordinates chosen. You can choose coordinates where a proper-rotating object is at coordinate-rest. In such coordinates there will be "fictitious forces" which will lead to the correct amount of proper rotation.
  • #46
Dale said:
Yes, completely.
So A would agree with B about the expected differences between their clocks due to gravitational time dilation. And the affect due to bringing the clocks together could be considered insignificant if the orbiting had gone on for long enough.
Would not A think, using the metric of A's clock, that B's clock had ticked less than would have been expected (taking gravitational time dilation into account) if it had been in A's rest frame, and B, using the metric of B's clock, think that A's clock had ticked less than would have been expected (taking gravitational time dilation into account) if A had been in B's rest frame?
  • #47
So with the A, B, and C coordinates it seems arguable that while the maths can model the relative motion regardless of which is thought to be at rest, only one rest frame would give the coordinate rotation which corresponds to the correct measurable proper rotation, without the addition of fictitious forces? Also I have read that fictitious forces are used with non-intertial frames of reference, but would not both A and B at rest both be intertial frames of reference (what intertial frame are they undergoing accceleration relative to)?
  • #48
Yes, as edited.
I have no idea how to parse the other question. In GR, the proper time on any clock undergoing any motion in any frame in any spacetime is given by ##\int \sqrt{ g_{\mu \nu} dx^{\mu} dx^{\nu}}##
Likes vanhees71
  • #49
Could you make up some figures for the scenario, and use them in the equation to demonstrate please (just so I can see how it works)?
P.S. Regarding where I had written: "So A would agree with B about the expected differences between their clocks due to gravitational time dilation." I had thought it was invariant how much difference would be expected due to gravitational time dilation. I thought in the Hafele-Keating experiment they had split the affects expected due to gravitational time dilation and kinematic time dilation to come up with their estimates, and so was thinking that you might be able to explain whether the expected gravitational time dilation affects would be same regardless of frame of reference, and if they were, and the coming together was insignificant (given long enough orbit), then simply explain why the kinematic time dilation expectations would be the same from each perspective, or how else they came to the same answer when added to the gravitational time dilation effects.
  • #50
Why don't you work through the first few chapters of Sean Carroll's lecture notes on general relativity first.
