ddddd28
- 73
- 4
Considering a body falls a free fall and g is changing, what is the formula of the height as a function of time?
How much maths do you know? Differential equations?ddddd28 said:Considering a body falls a free fall and g is changing, what is the formula of the height as a function of time?
ddddd28 said:Unfortunately not yet, I am still in high school. Can you show me the formula and explain it briefly?
ddddd28 said:It is too advanced for me.
ddddd28 said:yes of course, calculating the velocity is not a problem at all.
ddddd28 said:As far as I understand, at the points of perigee and apogee there is no radialic speed, so, it is calculated using the circular motion, isn't it?
If your problem involves elliptical motion knowledge, as you can guess, I will not be able to solve it.
ddddd28 said:The original question was asked because of pure curiosity. Is there any ellegent proof for that? and can you express the equation by only the distance between the objects, not the surface level?
ddddd28 said:is it √GM/r ?
Others may correct me if I am wrong, but I don't think there is a direct solution for finding distance as a function of time in this situation. You can find the time to fall a given distance by single equation, but not the other way around. You get the same problem with elliptical orbits. You can directly solve for the time it takes to travel from one point of an orbit to another, but you can't do so going the other way (except for when the two points are the periapis and apoapis.)ddddd28 said:Considering a body falls a free fall and g is changing, what is the formula of the height as a function of time?
Yes, but a planet in an elliptical orbit is a free falling object.FritoTaco said:I thought you were first considering a scenario of a free falling object?
This formula only is accurate for situations where g does not change with height. The original question dealt with the situation where it does, and this is something that must be accounted for with elliptical orbits.FritoTaco said:I was in high school last year, I only have half of my notes. Is this the formula? Unless your high school is more advanced, I don't remember using perigee and apogee.
h=12gt2h=\dfrac{1}{2}gt^{2}
Janus said:Yes, but a planet in an elliptical orbit is a free falling object.
