Answer: Time Ratio of Falling Rock from 100m Cliff
  • Thread starter Thread starter iloveuok
    Falling
iloveuok
Hi Guys,
Can someone help to answer this question?
A rock is dropped from a 100m high cliff. Determine the ratio for the time taken by the rock to fall the first 50m to the time taken for it to fall the second 50m
Thanks.
Regards,
Alex
Well,
What equation would you use in this case ?
What forces act on the object when it is falling down ?
What is the initial position and velocity ?
You need to show your work first. What have you done up till now ?
regards
marlon
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
