Frequency and viscous friction in a spring?
The relationship between frequency and viscous friction in a spring involves understanding Hooke's law and the dynamics of damped oscillators. The angular frequency is calculated using the formula w = square root of (k/m), where k is the spring constant and m is the mass. In a damped oscillator, viscous friction is modeled as proportional to velocity, which affects the system's behavior but not the frequency directly. To analyze the system further, one can solve the ordinary differential equation (ODE) using known values of the spring constant and frequency. This approach allows for the determination of velocity as a function of displacement.
nothGing
Hi.
may i ask the relationship(formula) between frequency and viscous friction in a spring?
are you talking about hookes law F=-Kx
And the angular frequency would be w=square root of k/m
your equation is right if not consider the viscous friction, but since it must consider the friction, so how arh?
In a damped oscillator the resistance is just modeled as proportional to velocity. The frequency has nothing to do with the friction force, it will just increase power delivered to the liquid.
If you know spring constant and frequency, then you can find v(x) by solving the ODE. I guess that's what you're asking.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
