Fresnel zone plate diffraction
The discussion revolves around the setup and calculations involved in using a zone plate as an enlarging lens, specifically focusing on its focal length, object distance, and image distance when illuminated by monochromatic blue-green light.
  • Participants explore the relationship between the radius of the zone plate and its focal length, questioning whether the given radius corresponds to r_0 or r_1. There is also discussion about using the thin lens equation and the geometry involved in the setup.
Some participants have provided guidance on interpreting the equations and applying the thin lens formula, while others express uncertainty about their understanding of the zone plate's function. There is acknowledgment of a diagram that may need correction, and the discussion remains open-ended regarding the accuracy of the original poster's representation.
Participants mention a lack of clarity in lectures and difficulty finding resources related to the problem, indicating potential gaps in foundational knowledge or available information on zone plates.
curto
A zone plate is to be set up on an optical bench, where it will be used as an enlarging lens. Its innermost zone is to be 0.2250 mm in diameter and monochromatic blue-green light of wavelength 480 nm from a cadmium arc is to be used. If the magnitude of the enlargements is to be eightfold in diameter, find:
(a) the focal length of the zone plate and
(b) the object distance and
(c) the image distance.
where n is an integer, r is the radius, and r_N and delta r_N are the outermost zone radius and its width.
this is my diagram which shows my current understanding of what's going on. i don't think it was taught very well in lectures and either I am not searching for the right thing on the net, or there's not information on this problem, or its so basic no one has bothered to put up any information on it. at the moment i don't really know where to go from here. we're given r_1 or r_0 (not sure if its 1 or 0), the wavelength and the enlargement magnitude. it looks like I am going to have to use some tricky geometry or something but I am honestly not sure what to do.
You should be able to tell from the first equation whether the quoted radius is [itex]r_0[/itex] or [itex]r_1[/itex].
Given that, it looks like you've got (a) from the first equation.
For monochromatic light you can basically treat a Fresnel lens as a "regular" thin lens (they have brutal chromatic aberration, though, and their off-axis performance isn't great, if memory serves). So parts (b) and (c) come from the usual lens formulae relating focal length and magnification to object and image distances.
ahh i see, first equation gives 10.5cm for f. that was simple, why didnt i see that before?? now i was thinking we just use the thin lens equation in the first place since all it was doing is the same thing a thin lens would do, but i wasnt sure because i don't fully understand what's going on in the zone plate. alright so that's answered everything basically, thanks! one last thing, is my diagram correct?
No. The recipe for geometric optics is to draw a point off-axis at the object distance. Draw a line from this point through the center of the lens. Draw another line from the point parallel to the axis until it strikes the lens, then draw a line from this intersection through the focal point on the other side of the lens. Where this line crosses the first line is where the image will be formed. You can then add arbitrary rays from the point to the lens and from the lens to the image of the point.
A zone plate is basically a diffraction grating designed to give a diffraction maximum at a distance f from the plate. The Wikipedia article isn't bad.
cheers
12K
