Frobenius solution to a diff-eq
  • Thread starter Thread starter IniquiTrance
    Frobenius
The discussion revolves around finding Frobenius series solutions to the differential equation 2xy'' + 3y' - y = 0. Initial attempts yielded roots r = -1/2 and 0, but the proposed solutions were deemed incorrect by others in the thread. It was noted that one solution should be a standard power series, as one root is zero, which contradicts the presence of a radical in both solutions. Further clarification was provided on how to properly use Mathematica to check solutions, emphasizing the need for correct syntax in the differential equation input. Ultimately, the conversation highlighted the importance of validating solutions against the original equation to ensure accuracy.
IniquiTrance
Find 2 Frobenius series solutions to the following differential equation:
2xy'' + 3y' - y = 0
I got r = -1/2 and 0 as roots.
Recurrence relation:
http://image.cramster.com/answer-board/image/cramster-equation-200951755626337813656283812509812.gif
I got the following solutions:
http://image.cramster.com/answer-board/image/cramster-equation-2009517550266337813622621312505598.gif
http://image.cramster.com/answer-board/image/cramster-equation-2009517551276337813628747875004691.gif
According to mathematica, these aren't the right solutions.
What am I doing wrong?
Thanks!
It's easy to see by plugging into the equation that those are NOT solutions to equation. Further since one of the solutions for r is 0, I don't see how you can get \sqrt{2x} in both solutions- one should be a standard power series.
<br /> <br /> It is a power series, I pulled out a radical so as to make it fit the form of sinh&#039;s power series.<br /> <br /> Do you disagree with my recurrence relation?<br /> <br /> Thanks for the response.
Really?
y_1(x)=\frac{a_0}{\sqrt{2x}}\sinh(\sqrt{2x})\implies y_1&#039;(x)=\frac{-a_0}{2\sqrt{2}x^{3/2}}\sinh(\sqrt{2x})+\frac{a_0}{2x}\cosh(\sqrt{2x})
\implies y&#039;&#039;(x)=\frac{-3a_0}{4x^2}\cosh(\sqrt{2x})+\frac{3a_0}{4\sqrt{2}x^{5/2}}\sinh(\sqrt{2x})+\frac{a_0}{2\sqrt{2}x^{3/2}}\sinh(\sqrt{2x})
\implies 2xy_1&#039;&#039;(x)+3y_1&#039;(x)-y_1(x)=\left(\frac{-3a_0}{2x}\cosh(\sqrt{2x})+\frac{3a_0}{2\sqrt{2}x^{3/2}}\sinh(\sqrt{2x})+\frac{a_0}{\sqrt{2x}}\sinh(\sqrt{2x})\right)
+\left(\frac{-3a_0}{2\sqrt{2}x^{3/2}}\sinh(\sqrt{2x})+\frac{3a_0}{2x}\cosh(\sqrt{2x})\right)-\left(\frac{a_0}{\sqrt{2x}}\sinh(\sqrt{2x})\right)=0And y_2(x) also satisfies the DE
y_1(x)=\frac{a_0}{\sqrt{2x}}\sinh(\sqrt{2x})=a_0\left(1+\frac{x}{3}+\frac{x^2}{630}+\ldots\right)
Is a regular power series:wink: (just multiply the series for sinh(\sqrt{2x}) by \frac{a_0}{\sqrt{2x}} )
Mathematica probably gave the total general solution as y(x)=\frac{e^{\sqrt{2} \sqrt{x}} C[1]}{\sqrt{x}}-\frac{e^{-\sqrt{2} \sqrt{x}} C[2]}{\sqrt{2} \sqrt{x}}...correct?
Which is actually equivalent to the linear combination of your two solutions with C[1]=\frac{a_0}{2\sqrt{2}}+\frac{b_0}{2} and C[2]=\frac{b_0}{\sqrt{2}}-\frac{a_0}{2}, since, by definition, \sinh(u)=\frac{1}{2}(e^u-e^{-u}) and \cosh(u)=\frac{1}{2}(e^u+e^{-u})
Oh, dear, oh, dear!:blushing:
Thanks!
http://img507.imageshack.us/img507/7167/71268782.jpg
I couldn't make heads or tails of that, and couldn't get the confirmation I needed.
I then tried plugging the result straight into the diff-eq, and mathematica likewise wasn't returning 0 as the answer, which spooked me.
IniquiTrance said:
Thanks!
In the above DSolve command, you need to use a "*" between x and y''[x] (i.e. 2x*y&#039;&#039;[x]), Mathematica interprets xy''[x] as the second derivative of a function called "xy"
As for checking that your solution satisfies the DE, try using FullSimplify[2x*y''[x]+3y'[x]-y[x]] after defining your y[x]
Ah, now that makes perfect sense! Thanks for your help.
You're Welcome!:smile:
