From field equation to equation of motion
Madster
Dear fellow relativiters,
I never fully got how to get from the field equations of Einstein's
R_{ \mu \nu} - \frac{1}{2} g_{ \mu \nu} R= -\frac{8 \pi G}{c^4} T_{ \mu \nu}
to a special metric, let's say the FRW metric
ds^2 = c^2 dt^2 - a(t)^2 \cdot (\frac{dx^2}{1-kx^2} + x^2 d\Omega^2)
and from there the equation of motion for a particle facing gravitational force.
In the above I left out \Lambda g_{\mu\nu} the term that represents that the metric itself is a solution and that gravity is repulsive on scales of vacuum energy.
So in Newtonian approximation I should get something like the inverse square law + \Lambda \cdot \vec{r} ?
Thanks
To get from the EFE to a specific metric, you just have to solve the EFE! In practice this means specifying a stress energy tensor. In the case of FRW, it's a perfect fluid. Then you impose homogeneity and isotropy, and literally compute the metric from the differential equations.
Since gravitational force don't exist in GR, you kind of have to do a Newtonian approximation to get such a thing to pop out.
The field equations are highly non-linear second-order differential equations. Only a few exact solutions are known, so you're going to be hard-pressed to try to solve them for a specific stress-energy.As for your question regarding a Newtonian Cosmological Constant, the form of the field equations with zero cosmological constant is:
G_{\mu \nu}=\kappa T_{\mu \nu}
Compare this with the analogous Poisson equation for Newtonian gravity:
\nabla^2 \phi =4\pi G\rho
The field equations with nonzero CC are:
G_{\mu \nu}=\kappa T_{\mu \nu}-g_{\mu \nu}\Lambda
Because the metric is analogous to the Newtonian potential, this suggests a modified Poisson equation of the form:
\nabla^2 \phi =4\pi G\rho-\phi \Lambda
However, if we assume the gravitational field is weak (which is the only time when Newtonian gravity is accurate anyway) and we linearize the field equations with g_{\mu \nu }=\eta_{\mu \nu }+h_{\mu \nu } and |h_{\mu \nu}|\ll 1, then we get the following field equations:
G_{\mu \nu}=\kappa T_{\mu \nu}-\eta_{\mu \nu}\Lambda
where G_{\mu \nu}=-\frac{1}{2} \partial^{\alpha} \partial_{\alpha}(h_{\mu \nu}-\frac{1}{2}\eta_{\mu \nu} h^{\sigma}_{~\sigma }), though the form of the Einstein Tensor isn't really important for our purposes. These field equations imply (because the 00 component of the Minkowski metric is of magnitude 1) a Newtonian Poisson equation of the following form:
\nabla^2 \phi =4\pi G\rho-\Lambda
This is clearly much simpler than the previous form we considered. If we switch to regular units and apply Gauss' Law to a spherically symmetric mass then we obtain a modified version of Newton's Law:
\nabla^2 \phi=\nabla \cdot (\nabla\phi )=\nabla \cdot(-\mathbf{g})
\int \nabla\cdot \mathbf{g}dV=\int \mathbf{g}\cdot d\mathbf{A}=\int (-4\pi G \rho +\Lambda c^2)dV
g\int dA=-4\pi G\int \rho dV + \Lambda c^2 \int dV
4\pi r^2g=-4\pi GM + \frac{4}{3}\pi r^3 \Lambda c^2
g=-\frac{GM}{r^2} + \frac{\Lambda c^2 r}{3}
\ddot{\mathbf{r}}=\left ( \frac{\Lambda c^2}{3}- \frac{GM}{r^3}\right )\mathbf{r}
The equation of motion for matter in a gravitational field generally requires separate postulates. However, specifying the form of the stress energy tensor in terms of the matter fields does place some constraints on the equations of motion for the matter fields, since the stress-energy tensor is divergence free according to the EFE. In some cases, the constraint is strong enough to specify the equations of motion for the matter fields completely. There is a discussion starting on p3 of http://arxiv.org/abs/1006.3903 .
atyy said:
You can't. The equation of motion for matter in a gravitational field is a separate postulate. For example, the equation of motion for the electromagnetic field in gravity is Maxwell's equations. The EFE and Maxwell's equations are a system of equations that must be simultaneously solved.
Well, it's relatively straightforward to derive the equations of motion straight from the metric:
\left (\frac{\partial}{\partial x^\mu } -\frac{d}{d\lambda} \left [\frac{\partial}{\partial(dx^\mu/d\lambda )} \right ] \right ) g_{\alpha \beta} \frac{dx^\alpha}{d\lambda} \frac{dx^\beta}{d\lambda }=0
Ignoring EM, there is no need for a separate postulate - first approximately circa 1938, Einstein, Infeld and Hoffman showed the geodesic postulate was unnecessary. It is has been proved a number of rigorous ways since then.
Even with EM, the way EM figures in the stress energy tensor leads to the result that solving the EFE for a body with charge and mass reproduces motion consistent with Lorentz force law.
For example, an early reference for the charged case is: http://prola.aps.org/abstract/PR/v95/i1/p243_1
Yes, I forgot about that. I changed my post while you were replying to my original version.
Hi, thanks that helped me but could you please explain what makes the metric an analogy to a potential. I mean the metric just implies the distance (dot prodict) of two line elements.
Is \lambda the parameter of the particle's path?
How to derive this formlular?
thanks
thanks
λ is called an affine parameter.try this
http://www.mth.uct.ac.za/omei/gr/chap6/node6.html
The field equations with zero CC simply say:
(second derivatives of the metric) = (constant)*(energy-momentum distribution)
The solution to this differential equation gives you a particular metric. Now, think about what Poisson's equation for Newtonian gravity says:
(second derivatives of the potential) = (constant)*(mass distribution)
The solution to this differential equation gives you a particular potential. The jump from Newtonian to Relativistic gravity is essentially one where the gravitational potential becomes a rank-2 tensor field (the metric) instead of just a scalar field.
thanks
λ is a general affine parameter. You derive that equation from the principle of extremal proper time. Proper time is given by a path integral which we can parametrize with an affine parameter λ:
\tau = \int \sqrt{-g_{\mu \nu} \frac{dx^\mu}{d\lambda} \frac{dx^\nu}{d\lambda}}d\lambda
So we see that the square root can be thought of as a Lagrangian (which we'll call L) that we can just plug into the Euler-Lagrange equation. It's easy to show that an equivalent Lagrangian is given by -L2, which helps simplify things a bit.
So if I get it correctly, what ever is linear in the potential in the Newtonian calculus, is in analogy linear in the metric in GR? Because the CC is linear with the metric in the field equation, I have to add a scalar field in the Poisson equation?
