From Infinity to Here: Explaining Objects, Escape Velocity & More
  • Thread starter Thread starter Goodies
    Infinity
The phrase "moving an object from infinity to a point" refers to the concept of analyzing gravitational interactions by considering two systems at an infinite distance apart, where their potential energy is zero. This approach allows for a clearer understanding of how gravitational or electrostatic forces affect the systems as they come closer together. Escape velocity, specifically for Earth at approximately 11 km/s, is the speed an object must reach to overcome Earth's gravitational pull and move away to infinity without additional propulsion. Essentially, if an object achieves this velocity, it can escape Earth's gravity and will not return. Understanding these concepts is crucial for grasping the dynamics of gravitational interactions in physics.
Goodies
A phrase that I heard several times in the 2 years of high school AP physics I've completed (being a computer science major, I haven't taken any physics classes in college) was moving an object from "infinity to a point" and I'm a little confused as to what that means and how it works.
Also, how does it fit with escape velocity? The escape velocity of the Earth is about 11km/s. This is also the velocity that an object would have when moved from infinity to Earth (assuming no other planetary object). I'd love an explanation. Thanks, guys! I appreciate any help!
When you have two systems that interact, for instance through gravitational or electrostatic interactions, you often want to compare to a situation where the two systems are present but not interacting. As the interactions do not turn off at a certain distance, but continue for ever, the only way to achieve this is to have them an infinite distance apart. If the potential energy due to the interaction is ##V(r)##, where ##r## is the distance between the systems, then ##\lim_{r \rightarrow \infty} V(r) = 0##. So you start by considering the systems an inifinite distance apart, and then bring them closer to investigate the effect of the interaction.
I've never heard used in that context, so I can't comment. Maybe someone else can chime in here.
What do you mean by "escape"? Any object, at any distance from the Earth will feels some small gravitational attraction and so eventually return to earth. To truly "escape" it must be able to go to infinity.
The "escape velocity" of an object is the velocity at a given instant such that, with its velocity decreasing as it moves away from Earth (due to gravitational pull back toward the earth), with no additional forces (in particular no rocket engines), it would, none the less, "escape" to infinity.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
