Function of enable input in gates
  • Thread starter Thread starter waqarrashid33
    Function Input
The enable input in gates functions as a control mechanism that determines whether the gate allows signals to pass through. For an OR gate, if the enable input is high, the output will always be high regardless of the other inputs. Conversely, if the enable input is low, the gate behaves normally, and the output depends on the state of the other inputs. This functionality allows for applications like frequency counting, where the enable input can be toggled to control the passage of input pulses. Understanding the enable input is crucial for designing circuits that require precise control over signal flow.
waqarrashid33
what are the function of enable input in gates?
If in or gate we use it and it is at high and the other two inputs are at low then what will be out put...1/0?
Please clear me about the enable input
If either input of an OR gate is high, then the state of the other input doesn't matter. The output will be high.
To allow input pulses to pass from input to output of the gate, then the "enable" input has to be low.
This input pin is no different to any other pin on the gate input, but its function makes it an "enable" (or disble) pin.
when the enable is at low the gate/I.C will be disable and when the enable is at high the gate/IC will be disable...but told that To allow input pulses to pass from input to output of the gate, then the "enable" input has to be low...what is correct..if you have any external link about it then please provide it..
waqarrashid33, for a good explanation of the "enable" function of logic gates see:
http://www.allaboutcircuits.com/vol_4/chpt_3/8.html
This only applies to an OR gate. Other gates are different.
http://en.wikipedia.org/wiki/Or_gate
As you can see, with an OR gate, if either or both of the inputs are high, then the output will be high. If they are both LOW, the output will be LOW
So, if you make one of the inputs LOW, then the output will depend on what the other input does.
If it is HIGH, the output will be HIGH, and if it is LOW, the output will be LOW.
Now, if you make the enable input HIGH, what can happen?
If the other input is LOW the output will be HIGH.
If the other input is HIGH, the output will be HIGH.
So the output will always be HIGH.
So, even if you put pulses (ie HIGH, LOW, HIGH...) on the other input, none of them will get through to the output.
That is why they call it a gate. It can let stuff through or stop it.
So what use is all this?
If you made the enable input LOW for exactly 1 second, you could use another circuit to count how many pulses got through and display this number on a display of some sort.
You would then have a frequency counter.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 16 ·
