Functions that integrate to a gamma function?
5 replies · 7K views
daviddoria
maple syntax:
int(theta^y * exp(-theta*(1-alpha) ) , theta)
I have a distribution that I need to integrate, and I know the result should have a gamma function in it.
The only thing I have found helpful is:
http://en.wikipedia.org/wiki/Gamma_function
My function is kind of in that form (theta^something * exp(something) ), but the "somethings" don't seem to be able to be manipulated into that form. Any hints on how to go about this?
Thanks!
David
You could match it with this generalized form of the gamma function (sometimes called the Plica Function):
[tex]\Gamma (a,z)=\int_z^{\infty } t^{a-1} e^{-t} dt[/tex]
Or you could also match it with the exponential integral function (n is an integer):
[tex]E_n (z)=\int_1^{\infty } \frac{e^{-z t}}{t^n} dt[/tex]
If you must match it to a non-generalized gamma expression, show us the final form you are aiming for.
I don't understand how I would match it with those? The problem is I have
t^alpha
and I need
t^(alpha - 1)
The only way I would know to "mold" mine into the correct one is to multiply by t^(-1) and t, then take t outside the integral and combine t^alpha with t^(-1) to get t^(alpha-1). However, t is the integration variable, so I can't do that!
any other thoughts?
Thanks,
David
Use the recursive property of the gamma function:
[tex]\Gamma(\alpha+1) = \alpha \Gamma(\alpha)[/tex]
This does require, however, that your limits of integration are 0 to infinity.
t^alpha
and I need
t^(alpha - 1)
Use integration by parts, differentiate t^alpha.
If the integral you are looking for is the following (assuming the limits are correct):
[tex]\int_{0}^{\infty}\theta^y \cdot e^{-\theta(1-\alpha)} d\theta[/tex]
You can transform it using:
[tex]\theta(1-\alpha)=u[/tex]
This gives you something related to the Gamma function.
