MHB Proof of Euler Tour in Graphs: In-degree($v$)=Out-Degree($v$)
  • Thread starter Thread starter evinda
    Euler
The discussion centers on the proof that a graph G has an Euler tour if and only if the in-degree equals the out-degree for each vertex. It explains that complex cycles can be decomposed into simple cycles, where each vertex in a simple cycle has an in-degree and out-degree of one. Questions arise about the necessity of showing that G does not exhaust all edges to prove it lacks an Euler tour, as well as the nature of G' after removing a cycle. The conversation also touches on the existence of cycles in connected components and the contradiction regarding the largest cycle. Additionally, an algorithm is proposed to find an Euler tour in O(E) time, emphasizing the need to check the in-degree and out-degree condition for all vertices.
evinda
MHB
Hello! (Wave)
I am looking at the proof that $G$ has an Euler tour iff in-degree($v$)=out-degree($v$), that I found at this site: https://www.cs.duke.edu/courses/fall09/cps230/hws/hw3/headsol.pdf (Problem 2)A simple cycle is a path in a graph that starts and ends at the same vertex without passing through the same vertex more than once.
A complex cycle, is a cycle that passes through the same vertex more than once. We can easily decompose a complex cycle to a set of simple cycles by breaking up the cycle at those points where the cycle passes through the same vertex more than once.
As the first part of our proof, we will prove that if $G$ has an Euler tour, in-degree($v$)=out-degree($v$) for each vertex $v \in V$.
We have already established that a comlex cycle can be decomposed to a collection of simple cycles. However vertices on a simple cycle have in-degree($v$)=out-degree($v$)=1.
Since each edge in a complex cycle, and therefore in an Euler tour, is part of one or more simple cycles it will have in-degree($v$)=out-degree($v$).
  • Could you give me an example of a complex cycle that is decomposed to a set of simple cycles, where we can see that in-degree($v$)=out-degree($v$)?
The second part of our proof requires us to prove that if in-degree($v$)=out-degree($v$) for each vertex $v \in V$, $G$ has an Euler-tour.
Let $C$ be the complex cycle involving the most edges in $G$.
In order for $G$ not to be an Euler tour, there must be some vertices that $C$ passes through ( since the graph is connected ) but does not exhaust all edges. We have already established that the vertices of a complex cycle have the property that in-degree($v$)=out-degree($v$). Therefore $G'=G-C$ will also have that property. If a connected component in a graph has in-degree($v$)=out-degree($v$) then it contains at least one cycle $C'$. However this contradicts our initial hypothesis that $C$ is the cycle involving the most edges in $G$ since we would construct a larger cycle by starting at some common vertex of $C$ and $C'$, traversing all of $C$s edges and then $C'$s edges. Therefore $C$ is an Euler tour.
  • First of all, it says that "In order for $G$ not to be an Euler tour, there must be some vertices that $C$ passes through ( since the graph is connected ) but does not exhaust all edges. "
    I haven't understood why we have to show that $G$ does not exhaust all edges. In order for $G$ not to be an Euler tour, couldn't it also hold that $G$ traverses an edge more than once?
    Then it says that "We have already established that the vertices of a complex cycle have the property that in-degree($v$)=out-degree($v$). Therefore $G'=G-C$ will also have that property."
    Why will $G'=G-C$ be a complex cycle, although $G$ isn't necessarily?
    Also, could you explain me why it holds that: " If a connected component in a graph has in-degree($v$)=out-degree($v$) then it contains at least one cycle $C'$."
    Finally, could you explain me the contradiction?
Technology news on Phys.org
I have also asked it here: The graph has an Euler tour iff in-degree($v$)=out-degree($v$) and I have understood it.
I also want to describe an algorithm that runs in time $O(E)$ and finds an Euler tour of $G$, if it exists.
(Hint: Merge edge-disjoint cycles.)
If we apply DFS, we will get a set of cycles formed by disjoint sets of edges, right? But how can we know if it holds that in-degree(v)=out-degree(v), for all vertices in $V$?
Do we have to do something like that?
Code:
Initialization(G)
    1. for each edge in G.E
    2.      e.color=WHITE
    3. DFS(G)
    DFS(G)
    1. for each vertex u in G.V
    2.      u.color=WHITE
    3. for each vertex u in G.V
    4.      if u.color==WHITE
    5.            DFS-VISIT(G, u)
     DFS-VISIT(G, u)
        1. u.color=GRAY
        2. for each v in G.Adj[u]
        3.      if (v.color==WHITE && (u,v).color==WHITE)
        4.          (u,v).color=GRAY
        5.          DFS-VISIT(G, v)
        6. u.color=BLACK
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
