What is the relationship between a laser's gain curve and its natural linewidth?
In summary: Ok, so in summary, the gain curve is a graph that depicts how much gain a particular frequency will have per round trip in the laser cavity. Actual gain will depend on mirror reflectivities. loop gain is a good way to depict the gain in a particular active medium without having to rely on parameters of the laser cavity.
Crumbles
138
Can someone please explain what exactly the gain curve of a laser is? Is it exactly the same thing as the natural linewidth of the laser [a graph of intensity vs frequency] or am I off track?
I found this graphhttp://www.phys.ksu.edu/perg/vqm/laserweb/Ch-5/C5s1p5.htm that tries to explain the gain curve but it has the y-axis labelled as GL, the loop gain. What exactly is this? Is it a measure of intensity/laser power?
Science news on Phys.org
A gain curve depicts how much gain a particular frequency will have per round trip in the laser cavity. Actual gain will depend on mirror reflectivities. Loop gain is a good way to depict the gain in a particular active medium without having to rely on parameters of the laser cavity.
The gain curve gives a general idea of how many longitudinal modes will appear and their relative intensities. For example, if the longitudinal mode separation was 1 THz and the gain curve had a width of 5 THz above threshold, you can expect about 5 longitudinal modes to appear, with the relative intensities of each tapering off as one moves from the centre of the gain curve.
The Gain curve is not the same as the natural linewidth of a laser.
Claude.
Ok, so would you say that the natural linewidth is the width of the mode that the laser is currently lasing at?
Or is the natural linewidth [as the term 'natural' suggests] the linewidth associated with a single photon as emited from an atom?
The natural linewidth is the linewidth due to natural broadening. Natural Broadening is due to the uncertainty of the width of the energy gap, which arises because of the finite lifetime of atoms in the upper state.
Typically the natural linewidth is about 8 MHz. The natural linewidth is dependant on the upper state lifetime.
There are other forms of broadening, such as Doppler broadening.
The linewidth of the emitted mode also depends on the finesse of the laser cavity.
Claude.
Related to What is the relationship between a laser's gain curve and its natural linewidth?
1. What is a gain curve for a diode laser?
A gain curve for a diode laser is a graph that shows the relationship between the output power and the current of the laser. It is used to determine the optimal operating conditions for the laser.
2. How is a gain curve measured?
A gain curve is measured by varying the current of the diode laser and recording the corresponding output power. This data is then plotted to create the gain curve.
3. What factors affect the shape of the gain curve?
The shape of the gain curve is affected by several factors, including the temperature of the diode laser, the materials used in the laser, and the quality of the mirrors and lenses used to focus the laser.
4. Why is the gain curve important?
The gain curve is important because it helps determine the optimal operating conditions for the diode laser. It also provides information about the efficiency and performance of the laser.
5. How can the gain curve be used in laser applications?
The gain curve can be used in laser applications to optimize the laser's performance and output power. It can also be used to troubleshoot any issues with the laser and make adjustments to improve its performance.
  • Beyond the Standard Models
  • MATLAB, Maple, Mathematica, LaTeX
