Gauss theorem and the nature of the surface
The discussion revolves around Gauss' law, specifically questioning the necessity of using a closed surface for calculations related to electric fields and enclosed charges. Participants explore the implications of open versus closed surfaces in the context of electric flux and the conceptualization of lines of force.
  • One participant questions why Gauss' law applies specifically to closed surfaces, arguing that the total number of lines of force should not vary between open and closed surfaces.
  • Another participant asserts that an open surface can yield arbitrary values and emphasizes the importance of enclosing the entire charge to avoid "leaks" in the calculation.
  • A participant challenges the concept of "lines of force," asking how a specific numerical value for lines of force can be derived from a charge in a vacuum if such lines do not exist.
  • One contributor explains that Gauss' law accounts for all electric flux through a surface and that an open surface would miss out on some of this flow.
  • Another participant highlights the issue of defining "enclosed charge" when using an open surface.
  • A participant expresses skepticism about the validity of a specific numerical value for lines of force, suggesting it lacks physical meaning and depends on the units used.
  • One participant references a textbook that claims a unit positive charge generates a specific number of lines of force, questioning how such an abstract concept can yield an exact number.
  • Another participant argues that discussing "lines of force" is pointless, stating that the concept is problematic and that the number of points in a field is infinite.
Participants express disagreement regarding the validity and meaning of "lines of force" and the necessity of closed surfaces in Gauss' law. There is no consensus on these points, with multiple competing views presented throughout the discussion.
Participants highlight limitations in the conceptual understanding of electric fields and the abstract nature of lines of force. The discussion reflects varying interpretations of Gauss' law and the implications of using open versus closed surfaces.
ananthu
According to Gauss’ law the total number of lines of force over a closed surface is equal to 1/ε times the net charge enclosed within the closed surface. Why should it be a closed surface but not an open surface too? I am unable to find a convincing explanation for it. Since we take into account only the number of lines starting or reaching a charge, the total number of lines is not going to vary whether we take a closed surface or open surface near the charge. Then why should it be specifically a closed one? Can anyone giving a convincing explanation?
If the surface is open, you can get any arbitrary value. It is important that you enclose the whole mass - without leaks, so to speak.
There is no "number of lines of force".
Thank you for the reply. If there is no lines of force, then how the calculated value of 1.129 x 1011 lines of force from 1 C of charge placed in air or vacuum arrived? What does that number exactly stand for? The value has been obtained from the formula 1/ε for air.
I am by means an expert but, what Gaus law does is to collect all that flows through a surface. If you don't totally enclose the charge there will be flow going out that you are not calculating.
Because only a closed surface can enclose a charge.
How do you define "enclosed charge" when your surface is open?
I have no idea who did that, but it is wrong.
Nothing.
$$\frac{1C}{\epsilon_0}=1.13\times 10^{11} Vm$$
The numerical value depends on the units you use - if you convert this to imperial units, you get a different number, for example. This alone shows that the numerical value itself cannot have a physical meaning (like some number of "lines").
This value has been given in the XII std physics textbook published by Tamil Nadu (India) government.
One of the properties of the electric lines of force given in the book is: "each unit positive charge placed in free space gives rise to 1/ ε lines of force, which works out to be equal to the quoted value taking ε for air as 8.854x10-12.
Though I could understand that the lines of force is merely an imaginary concept to visualize the electric flux, I find it difficult to convincingly explain how such an exact number could be specified when no one can count the number of lines of force as such, coming out of a closed area since such an idea is purely an abstract one. I will be happy if you could come out with a more convincing reply.
It is pointless to talk about a "number of lines of force". Such a thing does not exist.
I think "line of force" itself is a problematic concept, but at least it has some clear meaning (=field lines). Let's look at the points 1m away from a charge: Every point is on its own "line of force", and the number of points in a distance of 1m is infinite. There is no way to get any finite number for "lines of force". If you want to draw them, you have to restrict yourself to a finite number, but that is not an exact drawing of the field.
  • · Replies 83 ·
  • · Replies 30 ·
  • · Replies 36 ·
