Can Gaussian Elimination Solve a System with Identical Equations?
Gaussian elimination cannot yield a unique solution for a system with identical equations, such as 2x + 3y + 3z = 7 repeated three times. Instead, it results in an infinite number of solutions, as all points (x, y, z) on the corresponding plane satisfy the equation. The discussion emphasizes that despite having three equations, they represent the same plane in three-dimensional space. Thus, the system does not provide distinct values for x, y, and z. The key takeaway is that identical equations lead to a single plane with infinitely many solutions.
Biloon
2x+3y+3z=7
2x+3y+3z=7
2x+3y+3z=7
Using Gaussian Elimination... is it possible to find the value of x,y,z with three similar equation?
Mathematics news on Phys.org
absolutely not
Actually it is. Not ONE value of course, there are an infinite number of (x, y, z) triples that satisfy 2x+ 3y+ 3z= 7 and you really only have one equation. In 3 dimensions 2x+ 3y+ 3z= 7 is the equation of a plane. Any (x,y,z) point on that plane satisfies that equation (and so, all "three" of your given equations).
Haha, I was thinking the same thing.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
