Gauss's Law and Electric Field Question.
The discussion revolves around a problem involving Gauss's Law in the context of electric fields generated by charged objects. The scenario includes a plastic spherical shell with a uniform charge and a point charge located at its center, prompting questions about the electric field at a specific point relative to these charges.
  • Participants explore whether the electric field at point P1 is due solely to the point charge Q or if it also includes the contribution from the spherical shell charge q. There are inquiries about the implications of Gauss's Law and the shell theorem on the electric field within the shell.
Participants are actively questioning the assumptions regarding the electric field contributions from the charges involved. Some guidance has been provided regarding the nature of the electric field inside a uniformly charged shell, but no explicit consensus has been reached regarding the total electric field at point P1.
There are indications of potential misinterpretations in the questions posed, and participants are clarifying the conditions under which Gauss's Law applies, particularly in relation to the enclosed charges.
sanhuy
figure shows, in cross section, a plastic, spherical shell
with uniform charge q=16e and radius R. A particle
with charge Q = 5e is at the center.What is the electric field
(magnitude and direction) at (a) point P1 at radial distance a from Q
My question is at the point P1 is the electric field that the book found using gauss's law the total electric field or just the electric field due to Q (the point charge only).
This is worked out example 23.03 in the book "fundementals of physics 10e" by halliday and resnick.
Thanks.
Q/ε = ∫Eda
[/B]
My question is at the point P1 is the magnitude of the electric field found using Gauss's law due to Q, or both Q and q?
What does Gauss' Law state?
I believe it states that the total electric flux out of / into a closed surface is equal to the charge enclosed divided by the permittivity. it pretty much relates the electric field at points on a closed surface to the
net charge enclosed by that surface.
Sorry, Let me rephrase my question because there may be some misinterpretation. is the electric field that the book found using gauss's law the total electric field or just the electric field due to Q (the point charge only).
Are you familiar with the shell theorem?
No, not really. :\
wait, is the electric field inside of a shell zero due to symmetry if the charge is uniformly distributed on the spherical shell?
E is the electric field at the points of the Gaussian surface (the red sphere in your figure).
What charge is enclosed by your red Gaussian sphere that goes through P1? Is q inside it?
Well it only encloses the charge Q not q. So is the electric field calculated at P1 only due to Q? and the electric field due to q is zero at point P1 because of gauss's law?
is this correct?
thanks.
is this correct?
thanks.
Right.
Thanks guys.
  • · Replies 22 ·
  • · Replies 26 ·
