Gauss's law for electrodynamics
7 replies · 6K views
hercules68
Gauss's law can be proved qualitatively by proving that the field inside a charged closed surface is zero. However Maxwells' equations says that gauss's law holds true even for electrodynamics. how can this be verified experimentally? Thanks in advance !
Khashishi said:
Gauss's law is a specific case of Stoke's theorem.
http://en.wikipedia.org/wiki/Stoke's_theorem
Gauss' law is a law of physics that relates electric charges to electric fields.
Stoke's theorem is a purely mathematical statement, like the commutative property of addition.
I am not good in definitions but I did look into Gauss Law. I really don't see the relation of Stokes and Gauss. Even in Gauss law for magnetism:
http://en.wikipedia.org/wiki/Gauss%27s_law_for_magnetism
It only said [itex]\nabla \cdot \vec B = 0\;[/itex] where it states there is no mono magnetic pole.
Gauss law is mainly used in Divergence theorem where [itex]\nabla \cdot \vec E=\frac {\rho_v}{\epsilon}[/itex] Where:
[tex]\int_v \nabla\cdot \vec E dv'=\int_s \vec E\cdot d\vec s'=\frac Q {\epsilon}[/tex]
http://phy214uhart.wikispaces.com/Gauss%27+Law
The only one that remotely relate magnetic field through a surface is:
[tex]\int_s \nabla X\vec B\cdot d\vec s'=\int_c \vec B \cdot d \vec l'= \mu I[/tex]
that relate current loop with field through the loop.
1. The charged closed surface must be a conductor.
2. I don't know of any direct experimental test for a time varying E field.
The fact that its inclusion in Maxwell's equations leads to many verifiable results is an indirect proof of its general validity.
I just want to say that gauss law follow immediately from maxwell's fourth eqn when combined with continuity eqn for charge density.(just take the divergence)
I can't think of any direct prove on Gauss surface with varying charge inside. But I cannot see anything wrong that the total electric field radiate out of a closed surface varying due to vary charge enclosed by the closed surface still obey [itex]\int_s \vec E\cdot d\vec s'[/itex].
The difference is with varying charges generating the varying electric field, a magnetic field MUST be generated to accompany the varying electric field according to:
[tex]\nabla X \vec E=-\frac{\partial \vec B}{\partial t}[/tex]
Let us see,
c2(∇×B)=j/ε0+∂E/∂t
now,
c2{∇.(∇×B)}=∇.j/ε0+∂(∇.E)/∂t
USING ∇.j=-∂ρ/∂t and the fact that gradient of curl vanishes.
one gets,
∇.E=ρ/ε0
