MHB GCD: Fastest Method to Simplify Fractions
  • Thread starter Thread starter Petrus
    Gcd Method
The discussion centers on finding faster methods to simplify fractions, specifically questioning the efficiency of Euclid's algorithm. The user successfully simplified the fraction 196707/250971 to 29/37 using the GCD of 6783 but seeks alternative methods. Suggestions include the Trachtenberg Speed System and the Binary GCD algorithm, which could potentially streamline the process. Participants emphasize that each step in Euclid's algorithm involves division, implying that improving division techniques could enhance the overall speed of simplification. The conversation highlights a shared interest in exploring various mathematical approaches to fraction simplification.
Petrus
Hello,
I wounder if there is more method Then using euclides algoritmen to solve this problem
Simplifie/shorten(I Dont know how to say in english) $$\frac{196707}{250971}$$ and I get GCD=6783 and get the answer $$\frac{29}{37}$$ is there more method? Is there à method that is a lot more faster Then this one and that method you take out all prime number?
Mathematics news on Phys.org
Ackbach said:
There's a novel way of dividing numbers by others numbers of arbitrary length quickly.
How does division helps to simplify a fraction?
Petrus said:
Is there any method that is a lot more faster than this one
I don't see why you think Euclid's method is slow, can elaborate your logic a bit? Well, you might want to look at the Binary GCD algorith then since it shorten the work of finding the GCD quite a bit.
Naa its not really hard, I was just looking for more method to solve it :)
Each step of the Euclidean algorithm is a division problem, is it not? If you can speed up each step of Euclid's algorithm, then you speed up Euclid's algorithm.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
