MHB General motion in a straight line
The discussion revolves around calculating the total distance traveled in a motion problem involving integration of velocity functions over specified time intervals. The user successfully calculated the distance for the first interval but encountered discrepancies with the textbook answer for the second interval. They provided detailed integration steps but expressed uncertainty about potential calculation errors. Despite their efforts, the calculated total distance was 65.34m, while the textbook stated 69.2m. The conversation highlights the challenges of integrating piecewise functions and verifying results in physics problems.
Shah 72
MHB
I calculated (a)
I don't know how to calculate (b)
Mathematics news on Phys.org
after integrating both of them you will get this
Thank you so so so so much! That was so so helpful!
Can you also pls tell how to calculate 7(c).
I calculate s1 for interval between t=0 and t=1 and s2 for the interval between t=1 and t=5 by integrating their respective velocities. I did that and I get the ans 30m but the textbook ans is 69.2m. Pls help
For $0 \le t \lt 1$ $s= 1/2 t^2 + 2/3 t^3$ putting t=1 we get 7/6
For $1 \le t \le 5 $ $v= 30/4 t + 5/4 t^{-2} - 23/4 $ integrate and putting limits we get $x-7/6 = (15/4) (5^2 - 1^2) + (5/4)(1- 1/5)+ (23/4)(1-5)$ I'm getting x =63 + $7 \over 6$ So total distance = 63 + $7 \over 3$ = 65.34
Even I am also not getting the answer may be I made a calculation mistake or the answer is wrong. Afaik this will be done here.
Thank you very much!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
