General Question About a System of DE's
8 replies · 2K views
transmini
We were looking at some examples of systems of differential equations in class a couple days ago, and some of them were simple looking systems. One such was
##\frac{dr}{dt} = 4j##
##\frac{dj}{dt} = r##
Why is it that we can't treat this as a scenario where both sides of each equation could just be integrated immediately or something like in physics where the first equation would become ##dr = 4jdt## and then integrate? (I have a question current posted in the calculus section about splitting the derivative if anyone cares to answer when this technique DOES work)
If j and r were constants, you could do this, but the implication is that both j and r are unknown functions of t.
It's exactly the same as trying to evaluate this integral: ##\int f(x) dx##, without knowing anything about f.
Also, if this were your system...
##\frac{dr}{dt} = 4r##
##\frac{dj}{dt} = j##
... then you could separate each equation like so:
##dr = 4rdt \Rightarrow \frac{dr}r = 4 dt \Rightarrow \int \frac{dr}{r} = 4 \int dt \Rightarrow \ln|r| = 4t + C##
Exponentiating both sides would yield ##|r| = Ae^{4t}##, where ##A = e^C##.
The other equation could be solved in a like manner.
Perfect, that explanation helped a lot. Thanks!
Well couldn't you rewrite on vector form and then integrate to get a matrix exponential?
Set ## v =(r,j) ## such that we get the equation
## \frac{d}{dt}v = (0,4;1,0)v ##,
and then integrate.
and then integrate.
It's a lot more complicated than this. If you integrate as you suggest you get a solution that contains this factor:
$$e^{\begin{bmatrix} 0 & 4 \\ 1 & 0 \end{bmatrix}~t}$$
Expanding that exponential is difficult, as it involves an infinite number of terms, each requiring a higher power of that matrix.
The usual technique involves finding a diagonal matrix D that is similar to the matrix above; that is, a matrix ##D = P^{-1}AP##, where the eigenvalues of matrix A appear on the diagonal in D, and the eigenvectors of A are the columns of P. For more information, see any differential equations textbook that has a section on solution of systems of diff. equations using matrix diagonalization.
As far as I know solving simple matrix exponentials is taught very early on at universities. I would not call it more complicated but certainly less used.
Yes, that's about right.
It's quite complicated in comparison to matrix addition and multiplication, and even finding the inverse of a matrix. For diagonalization, you need to find the eigenvalues, find the eigenvectors, form a matrix whose columns are the eigenvectors, find the inverse of that matrix, and so on.
But you can still find the matrix exponential. At any rate. The question was why can't we just integrate both sides and my answer is: you can but you will have to solve something different instead.
