General Relativity - Circular Orbit around Earth
32 replies · 4K views
unscientific
(a) Find the proper time in the rest frame of particle
(b) Find the proper time in the laboratory frame
(c) Find the proper time in a photon that travels from A to B in time P
Part(a)
[/B]
The metric is given by:
[tex]ds^2 = -\left( 1 - \frac{2GM}{c^2r} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) dr^2[/tex]
Circular orbit implies that ##dr^2 = 0##, so
[tex]ds^2 = c^2 d\tau^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2[/tex]
[tex]\left( \frac{d\tau}{dt} \right)^2 = \left( 1 - \frac{2GM}{c^2R} \right)[/tex]
[tex]\frac{d\tau}{dt} = \sqrt { \left( 1 - \frac{2GM}{c^2R} \right) }[/tex]
Since the time between event A and B is ##dt = P##, the time experienced in the rest frame must be ## d\tau = \sqrt { \left( 1 - \frac{2GM}{c^2R} \right) } P ##?
I'm not sure how to approach parts (b) and (c)..
Does ##dx^2 + dy^2 +dz^2 = 0## for two neighboring points on the orbit?
They are at the same radius, so yes.
For general motion in the xy plane (z = 0), how would you express ##dx^2+dy^2## in polar coordinates ##(r, \theta)##?
[tex]r^2sin^2 \theta d\phi[/tex]
TSny said:
Oh I must have confused the r's. It should be:
[tex]ds^2 = -\left( 1 - \frac{2GM}{c^2r} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) R^2 d\phi^2[/tex]
Since for ##z=0## we let ##\theta = \frac{\pi}{2}##.
On the circular orbit of radius R, what is the value of little r?
r = R
Right.
[tex]ds^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) R^2 d\phi^2[/tex]
Using ## d\phi = \omega dt = \frac{2\pi}{P} dt ##
[tex]ds^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2 R} \right) R^2 (\frac{2\pi}{P})^2 dt^2[/tex]
Not quite. Does ##R^2P^2dt^2## have the correct dimensions of distance squared?
Using ## d\phi = \omega dt = \frac{2\pi}{P} dt ##,
[tex]-c^2 d\tau^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2 R} \right) R^2 (\frac{2\pi}{P})^2 dt^2[/tex]
[tex]\left( \frac{d\tau}{dt} \right)^2 = \left( 1 - \frac{2GM}{c^2R} \right) - \left( 1 + \frac{2GM}{c^2 R} \right) R^2 \left(\frac{2\pi}{Pc}\right)^2[/tex]
Looks good.
TSny said:
Looks good.
I am stuck on part (b) though..
What is ##dx^2 + dy^2 + dz^2## for a fixed point on the orbit?
For a fixed point, it is ##0##, so ##\frac{d\tau}{dt} = 1 - \frac{2GM}{c^2R}##.
...and ##ds^2 = ##?
TSny said:
...and ##ds^2 = ##?
Solving, we get ## \frac{d\tau}{dt} = 1 - \frac{2GM}{c^2R} ##.
For part (c), since beam of light travels at speed ##c## in all frames, is ##dr^2 = c^2 dt^2 = c^2 P^2##?
unscientific said:
For part (c), is ##dr^2 = c^2 dt^2##?
No. ##dr/dt## for the radially traveling light pulse is just a "coordinate speed of light" and need not equal c.
But no matter what the coordinate speed of light, what is ##ds## for any two neighboring space-time events on the worldline of a light pulse?
TSny said:
No. ##dr/dt## for a light pulse is just a "coordinate speed of light" and need not equal c.
Time-like, no rest frame. so ##ds = 0##.
It's neither spacelike or timelike. It's "lightlike". Yes, ds = 0.
TSny said:
Yes.
So does this mean the equation is simply:
[tex]0 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) R^2 d\phi^2[/tex]
[tex]0 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2[/tex]
The light is traveling radially. So, what is ##dx^2 + dy^2 + dz^2## in polar coordinates?
But, you are interested in the proper time. How is ##ds## related to ##d\tau##?
Since it is only moving radially, ##d\phi = 0## so ##dx^2 + dy^2 = dr^2##.[tex]ds^2 = -\left( 1 - \frac{2GM}{c^2r} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) dr^2[/tex]
[tex]ds^2 = -c^2 ~ d\tau^2 = 0[/tex]
OK, but you don't need the metric for part (c).
You know ##ds^2 = -c^2d\tau^2##. So, for an increment along the light path, what is the change in proper time ##d\tau##?
I don't understand why it isn't simply ## ds^2 = -c^2 ~ d\tau^2 = 0 ##
That's correct.
TSny said:
That's correct.
So the result doesn't really say anything other than:
which means either ##dt = 0## which is not possible since ##dt = P##. Therefore it implies that ##R = \frac{2GM}{c^2}##, which happens to be the schwarzschild radius.
