Generalized Green function of harmonic oscillator
Dustinsfl
The generalized Green function is
G_g(x, x') = \sum_{n\neq m}\frac{u_n(x)u_n(x')}{k_m^2 - k_n^2}.
Show [itex]G_g[/itex] satisfies the equation
(\mathcal{L} + k_m^2)G_g(x, x') = \delta(x - x') - u_m(x)u_m(x')
where [itex]\delta(x - x') = \frac{2}{\ell}\sum_{n = 1}^{\infty}\sin(k_nx)\sin(k_nx')[/itex]
and the condition that
\int_0^{\ell}u_m(x)G_g(x, x')dx = 0.
From a previous problem, I found
u_n(x) = \sqrt{\frac{2}{\ell}}\sin(k_nx).
I then end up with
\begin{gather}
(\mathcal{L} + k_m^2)G_g(x, x') = \frac{2}{\ell}\sum_{n = 1}^{\infty}\sin(k_nx)\sin(k_nx') - u_m(x)u_m(x') \\
\sum_{n\neq m}^{\infty}\sin(k_nx)\sin(k_nx') = \left(\sum_{n = 1}^{\infty}\sin(k_nx)\sin(k_nx')\right) - \sin(k_mx)\sin(k_mx')
\end{gather}
What is going wrong?
$$G_g(x, x') = \sum_{n\neq m}\frac{u_n(x)u_n(x')}{k_m^2 - k_n^2}.$$ Show [itex]G_g[/itex] satisfies the equation
$$(\mathcal{L} + k_m^2)G_g(x, x') = \delta(x - x') - u_m(x)u_m(x')$$ where [itex]\delta(x - x') = \frac{2}{\ell}\sum_{n = 1}^{\infty}\sin(k_nx)\sin(k_nx')[/itex] and the condition that
$$\int_0^{\ell}u_m(x)G_g(x, x')dx = 0.$$
$$u_n(x) = \sqrt{\frac{2}{\ell}}\sin(k_nx).$$ I then end up with
\begin{gather}
\end{gather}
Why do you think anything is going wrong? Please explain what you did. I can't tell if you just plugged in the expression for ##\delta(x-x')## to get the first line or if you evaluated the lefthand side and got the righthand side or did something else.
The Fourier method to solve differential equations is always to make an ansatz of the unknown function in terms of a Fourier series. In your case
[tex]G(x,x')=\sum_{n=1}^{\infty} A_n(x') u_n(x).[/tex]
Then you apply the operator, [itex]\mathcal{L}+k_m^2[/itex] to this ansatz, expand the inhomogeneity of the equation also in terms of a Fourier series and then compare the coefficients on both sides, which let's you solve for [itex]A_n(x')[/itex].
Note that in this case, where [itex]\lambda=-k_m^2[/itex] is an eigenvalue of [itex]\mathcal{L}[/itex], the inhomoeneity must be perpendicular to the eigenfunction [itex]u_m[/itex] for consistency. That's why you have to subtract the part parallel to this eigenmode. Note also that any solution of the inhomogeneous equation is only determined up to a function proportional to this eigenmode!
