Generating Random High/Low Sounds Using PIC Controller?
  • Thread starter Thread starter Pr0t0n
    Controller Random
To generate random high/low frequency sounds using a PIC12F675P controller, one can utilize bit-banging on a GPIO pin at audio rates. Implementing a random number generator is essential for determining frequency and duration, with an LFSR algorithm being a recommended approach. For more complex waveforms beyond simple square waves, additional methods must be explored to achieve the desired sound quality. Connecting the PIC to a DTMF chip or implementing a simple modem with external filters may enhance sound accuracy. The approach taken will depend on the specific sound fidelity required, such as mimicking a dial-up modem.
Pr0t0n
I'm new to the electrical engineering field and need guidance on how I can program a PIC (PIC12F675P) controller to generate random high/low frequency noises through a amplifier (TDA2822M). The sounds I'm aiming for need to be similar to those generated by a dial up modem.
I will appreciate any guidance I can get.
The simplest is to just bit-bang a pic IO pin at audio rates. Deciding what frequency for what duration to generate (ie, random) requires some sort of random number generators constrained to to provide numbers withing the frequency range and durations of the sounds you desire. If you want changing amplitudes, that would be a third number required. An lfsr algorithm will generated pseudo random numbers. See http://en.wikipedia.org/wiki/List_of_random_number_generators. Here is some PIC code for such a thing: http://www.dontronics.com/psbpix/random.html
If you want waveforms that are not simple squarewaves, then you need to determing how to generate the waveform you want.
Thank you meBigGuy! Let me see how far I can get with this now.
you could always hook it up to a dtfm chip.
My GPIO solution is pretty simplistic, but I don't know how accurate you need the sounds to be. That is, how much like a 1200 baud, or 2400 baud or whatever. The square wave won't sound exactly like a modem. thankz suggestion will sound exactly like a modem since it will be one. or, you can possibly implement a simple modem in the pic and some external filters to get the sound right. I don't know what you are really striving for.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 31 ·
  • · Replies 26 ·
