Generator types in wind turbines
The discussion focuses on the types of generators used in wind turbines, highlighting that the majority of small units are simple 12-14v DC generators, commonly found in RVs and boats. For large power installations, doubly-fed asynchronous machines (DFAS) are preferred due to their efficiency and compatibility with grid systems. Estimates suggest that over 97% of large wind turbines utilize DFAS technology. Newer trends indicate a shift towards directly driven permanent magnet synchronous machines, reducing reliance on gearboxes. Specific statistics on generator types remain elusive, with inquiries to organizations like the EIA yielding no responses.
EEwyoming
What are the percentages of types of generators commonly used in wind turbines? To clarify, what percentage are regular squirrel-cage machines? What percentage are doubly-fed machines, permanent magnet machines, synchronous machines, and so on. I'm looking for a general idea of these statistics.
...Or where can I look to find this information?
It depends what you are considering.
By number the majority will be simple 12-14v dc generators simply because most wind generators out there are small units used for RVs or boats.
For large power installations most modern systems will be double fed asynchronous because it's the most efficent and these systems have complex power controllers anyway to be able to feed to the grid.
Thanks mgb, here I'm referring to wind farms and large systems tied to the grid.
From what I've seen, the doubly-fed is the first choice usually, as you say. However, I'm hoping to find some specific statistics and I haven't been able to. I've even tried contacting the EIA. No reply. Any wind experts out there know?
In my experience, probably 97%+ are DFAS machines. The newer technologies are starting to get away from using gearboxes and use directly driven PM synchronous machines.
Thanks Topher
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
