Geometric Optics - Magnification
The problem involves a concave mirror and the relationship between object distance, image distance, and magnification. The original poster describes a scenario where an image is formed that is twice the size of the object, followed by a change in conditions resulting in an image three times the size of the object. The challenge is to determine how far the object moved when the screen was moved a specified distance.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to establish relationships between object and image distances using magnification equations. Some participants question the clarity of the problem statement regarding the movement of the screen and object. Others suggest defining variables to clarify the relationships and equations involved.
Participants are engaged in exploring the problem, with some providing guidance on how to set up equations based on the relationships described. There is an ongoing dialogue about the correct interpretation of the problem and the necessary equations to solve it, but no consensus has been reached yet.
There is some confusion regarding the wording of the problem, particularly about which elements are moving. The original poster has clarified that the object and screen are moved while the mirror remains stationary.
LANS
A concave mirror forms an image on a screen twice as large as an object. Both object and mirror are then moved such that the new image is 3x the size of the object. If the screen is moved 75cm, how far did the object move?
m = image distance / object distance
Initially, the screen is twice as far from the mirror than the object. The screen and object move so that the screen is three times as far from the mirror as the object. I'm really at a loss and feeling kinda dumb here on solving this - any pointers in the right direction would be much appreciated.
Thank you,
LANS
Is that exactly how the question was worded? It sounds a bit off because it says the object and mirror are moved, implying the screen stays put, but then it says the screen was moved.
Sorry, I miswrote it. The object and screen moved, mirror stays in the same place.
OK, let's define some variables:
\begin{eqnarray*}
d_\text{obj} &= \text{initial object distance} \\
d_\text{img} &= \text{initial image distance} \\
r_\text{obj} &= \text{final object distance} \\
r_\text{img} &= \text{final image distance} \\
f &= \text{focal length of the mirror}
\end{eqnarray*} So you have five unknowns. You have ##d_\text{img}/d_\text{obj} = 2## and ##r_\text{img}/r_\text{obj} = 3## so far. That's two equations. Can you come up with any more?
There's 1/d_I + 1/d_o = 1/f (and same for r_I, r_o), and r_I - d_I = 75, I'm just not sure how to approach it algebraically.
OK, good. Since you're looking for how far the object moved, you might want to get equations in terms of the object distances, so I'd use the magnification equations to solve for the image distances in terms of the object distances and then substitute the results into the three remaining equations.
Try writing those out and see if you can see where to go from there. Sometimes you just have to write equations down and try stuff, and then it becomes clear what to do.
  • · Replies 16 ·
