Getting a reduced voltage from a fixed secondary voltage of a transformer
  • Context: Undergrad
  • Thread starter Thread starter avicenna
    Copper Windings
The discussion revolves around the behavior of a choke connected to a transformer and the feasibility of using it to obtain a reduced voltage for a 6V filament lamp from a 12V transformer secondary. Participants explore the implications of connecting inductive loads to transformers, including voltage measurements, impedance considerations, and the nature of reactive power.
  • Some participants assert that connecting an inductor to a transformer will result in the transformer secondary voltage appearing across the inductor, with a measured value of 12 Vac, assuming the transformer can provide the necessary current.
  • There is a proposal to use a variable resistor in series with a 6V filament lamp to tap 6V AC from a 12V supply, contingent on the lamp's operating resistance being lower than the variable resistor's maximum value.
  • Concerns are raised about the impedance of a choke, with some participants noting that a good choke has low series resistance but high reactance, leading to low current draw.
  • Participants discuss the formula for impedance magnitude, noting that it depends on frequency and the inductance of the choke, with some approximating resistance as negligible in certain scenarios.
  • One participant questions the rationale behind connecting an inductor across a transformer, highlighting that this could lead to reactive power issues and potential penalties from the power supply authority.
  • A participant shares their practical experience of building a home transformer, providing details about their winding configuration and output voltage, indicating a successful application of the discussed concepts.
Participants express differing views on the implications of connecting inductive loads to transformers, particularly regarding current draw and power factor. There is no consensus on the best practices or outcomes related to the use of chokes with transformers.
Some discussions include unresolved definitions and assumptions, such as the specific values of inductance and resistance, as well as the implications of reactive power in practical applications.
avicenna
TL;DR
Getting a reduced voltage from a fixed secondary voltage of a transformer.
1) I have a "choke" with many copper windings on a soft iron core. I connect it to the 12V secondary of a mains transformer. I measure the voltage of the choke with a multimeter. What is the value and why?
2) I want to light up a 6V filament lamp. My supply is a 12V from a step down transformer. Can I try to tap 6V AC for the lamp by having my lamp in series with a variable sliding resistor 50Ω and gradually reducing the resistance.
If you connect an inductor to a transformer, the transformer secondary voltage will appear across the inductor. Voltage value = 12 Vac. That assumes the transformer is able to provide the current drawn by the inductive choke.
If the 6 volt filament lamp has an operating resistance lower than 50 ohms, (that can be matched by the variable resistor), then you will be able to adjust the resistor, so half the voltage appears across the lamp.
[Typo fixed]
If the 6 volt filament lamp has an operating resistance lower than 500 ohms, (that can be matched by the variable resistor), then you will be able to adjust the resistor, so half the voltage appears across the lamp.
Thanks. Very helpful.
Isn't it true that a good choke/inductor has very high impedance? So the current drawn "I" would be very small. Primary current about I * 240/12.
NOTE: your typo error. It is 50 ohm
Do not maximise the impedance, Z = R + j·X
A good choke has low series resistance, R, but high reactance, X.
DaveE said:
The impedance magnitude would depend on the frequency ##|Z| = \sqrt{R^2 + (2 \pi f L)^2}##
https://www.khanacademy.org/science...-analysis-topic/ee-ac-analysis/v/ee-impedance
Say the choke has sufficient/many copper turns and we approximate ignoring R; R= 0.
So Z = 2π * 50 * L ohm may (generally) be high. So secondary current I = 12 / Z generally low.
Primary current = I * 12/ 240 (earlier post typo as I * 240 / 12) is usually within limit of primary current rating.
I don't know. I think you are thinking about this correctly. But your questions are completely undefined.
What is ##L##, what is "high"? I've done designs where 1Ω is very low, and other designs where 1Ω is very high.
I don't know your source current ratings. You'll need to ask more specific questions I think.
The transformer primary is designed to be inductive, sufficient to limit the magnetising flux in the transformer.
Why would you connect an inductor across a transformer?
The current that flows will be in quadrature to the transformer secondary voltage, so the power will be reactive, not real, it will be circulating energy between the power generator and your inductor. That is not a good power factor, you will upset the supply authority, and pay a penalty rate for heating their wires with; W = I²·R
My apology. I am no expert, just asking a theoretical question about putting an inductor as load to a transformer.
My questions now all cleared. I just built a crude home transformer for some purpose. I wound 100 turns AWG 19 copper wires over a 16mm upvc tube as secondary. My primary 100 turns is wound over my secondary. I put 6 long steel bolts inside the upvc tube as core. It works. Input of 1.5V gives output of 0.7V. This is what I wanted.
Thanks for your help.
9K
