Given a Constant Acceleration magnitude of g/4, Find the value of t
The discussion revolves around a problem involving constant acceleration, specifically with a magnitude of g/4, and seeks to find the time variable t related to the motion of a sandbag released from a balloon. The context includes quadratic equations of motion and the transition from upward acceleration to free fall.
  • Mixed
  • Participants explore the derivation of a quadratic equation related to the motion of the sandbag and question the correctness of the approach taken. There are inquiries about the initial conditions, such as the velocity of the sandbag at the moment of release, and the interpretation of the problem's wording regarding time units.
Some participants have provided feedback on the original poster's approach, suggesting that the method may be correct while also prompting checks on specific details like the signs in calculations. There is an ongoing exploration of the problem's setup and the implications of the wording used in the question.
Participants note potential ambiguities in the problem statement, particularly regarding the phrasing of the time measurement and the implications for unit selection. There is also a mention of the transition from acceleration to free fall, which may affect the interpretation of the motion involved.
baumbad
A hot-air balloon takes off from the ground traveling vertically with a constant upward acceleration of magnitude g/4. After a time interval Δt, a crew member releases a ballast sandbag from the basket attached to the balloon.
How many seconds does it take the sandbag to reach the ground? Express your answer in terms of Δt.
s = ut + 1/2at^(2)
I got to the quadratic equation of the motion where: 4gt^(2) - g(delta t)t - g(delta t) = 0 and tried to solve for t. In this case, we would take the positive discriminate since we are dealing with the passing of time.
t = ((sqrt(17) g(delta t)) + g (delta t)) / (8g)
However, this is the wrong answer and I am not sure why.
Please show the steps by which you got that.
What was the velocity of the sandbag when it was released?
this is the work that I used, however, I'm not sure that this is the correct approach. At a particular time, the sandbag goes from an upward acceleration of g/4 to free fall.
Your approach looks correct. You have two equations with arrows pointing at them. Check how you get from the first one to the second.
Thank you very much for your help!
Also check the signs in the final step.
Note that the question should have asked "how much time", not "how many seconds".
As written, it is a bit tricky to pick the right units for the required answer.
  • · Replies 26 ·
  • · Replies 21 ·
