Given initial angular velocity of wheel, find revolutions to rest
The discussion revolves around calculating the number of revolutions a wheel makes before coming to rest, given its initial angular velocity and a frictional decay model. The angular speed is described by the equation dθ/dt = 4.1e^(-0.088335775t), with the initial velocity set at 4.1 rad/s. To determine the time until the wheel stops, the user attempts to set the equation to zero but encounters issues with the natural logarithm of zero. The solution involves finding angular acceleration and using integration to calculate total angular displacement, which ultimately allows for the determination of the number of rotations. The conversation highlights the mathematical approach needed to solve the problem effectively.
pengwum
SOLVED Given initial angular velocity of wheel, find revolutions to rest
As a result of friction, the angular speed of a
wheel changes with time according to
d \vartheta / dt = 4.1e-.088335775t
where the initial angular velocity is 4.1 rad/s.
Find the number of revolutions it makes before coming to rest.
d \vartheta / dt = 4.1 rad/s-.088335775t
To find the time needed for the wheel to rest, I set the left side of the equation to 0, but to find t, I had to find the natural log of both sides. However, ln of 0 does not exist...so now I am at a loss. Any help would be appreciated...thanks!
First of find the angular acceleration by taking he derivation of angular velocity.
α =kω, where k = -0.08833577.
Then use the equation θ =Intg [( ω^2 - ωο^2)/2α]*dω between the limits ωο to 0, find the total angular displacement. From that you can find the number of rotations.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 19 ·
  • · Replies 32 ·
