Good LED bulb will not work in a socket
The discussion revolves around a specific issue with a dimmable LED bulb that does not function in a particular lamp circuit, despite other bulbs working correctly. Participants explore potential causes related to the dimmer, voltmeter, and the compatibility of the bulb with the circuit.
  • One participant describes a science project lamp setup with a dimmer, voltmeter, and socket, noting that a newly purchased LED bulb does not light up despite working in other lamps.
  • Another participant questions whether the problematic bulb is identical to a working one, clarifying that it is a similar vintage-style bulb but not identical.
  • Concerns are raised about the inline voltmeter potentially affecting the bulb's operation.
  • Some participants suggest that the dimmer may be the issue, while others point out that all other bulbs work with the dimmer.
  • There is a discussion about the compatibility of LED bulbs with dimmers, with some arguing that not all LED bulbs are made the same and may not work with every dimmer.
  • A participant mentions that the dimmer may have failed, leading to a situation where all bulbs stopped working, which was later confirmed when a new dimmer restored functionality.
  • Confusion arises regarding the wiring setup, with participants discussing the roles of hot and neutral wires in relation to the dimmer and voltmeter.
Participants express differing views on the cause of the issue, particularly regarding the dimmer's functionality and the compatibility of the LED bulb. The discussion remains unresolved until a participant identifies that the dimmer had failed.
There are inconsistencies in descriptions of the wiring setup, leading to confusion among participants about how the circuit is configured. The discussion reflects uncertainty about the interaction between the dimmer, voltmeter, and LED bulb.
Individuals interested in electrical circuits, dimmable LED technology, and troubleshooting electrical issues may find this discussion relevant.
ILoveDeoxit
TL;DR
I don't even know where to start.
Hi all,
25 year electrician here with a strange (to me) issue.
I have a science project lamp that has a dimmer, a volt meter and a socket with a bulb in it. The kids can turn on the bulb, rotate the dimmer and watch the voltage go up and down on the meter. Simple enough.
Every dimmable bulb (including LED's) I have put in it works perfectly. Until now.
Lowes sells a large globe vintage style General Electric LED bulb and I purchased one. Long story short, It will not light up in this circuit for some reason. This bulb works in every other lamp I tried it in, the bulb is fine.
I eliminated the socket as the problem by jumping the wires straight to the bulb and still nothing.
I tried a similar LED bulb, same style, design and it works. Every other bulb in the house works in this circuit except the one I just bought.
Can anyone explain this to me?
ILoveDeoxit said:
Summary:: I don't even know where to start.
You mean you purchased an identical bulb ? (And it works? )
No, I have other LED bulbs that are built the same way (vintage style) but they are regular sized bulbs.
For the record, VOM shows a solid 119 volts at the socket. All I can think of is somehow the inline volt meter is effecting this bulb somehow? There is really nothing else to question.
You said there is a dimmer, not only a voltmeter?
Correct. Simple circuit... Dimmer to voltmeter to bulb.
Voltmeters are not used inline. A more detailed description and schematic would be helpful.
I would put the bet on the dimmer.
I would suspect the dimmer but every other bulb in the house works in it.
Its like this...
Rotary Lutron dimmer to panel volt meter to bulb.
Could you show some wires, perhaps?
120 volt
hot/neutral to dimmer, hot and neutral to the meter and then to the socket. Thats it.
Doesn't matter much. LED bulbs have their own switchers which don't have to be compatible with the dimmer. It is not like every LED bulb is made exactly the same way.
I suppose its possible but Lutron would be the De facto standard if there is one for dimmers. :rolleyes:
I would think A GE bulb that says "dimmable" should work with a Lutron dimmer.
That would not be a wise assumption
ILoveDeoxit said:
120 volt
That makes no sense.
Borek you nailed it...
Not sure what happened but finally all the bulbs stopped working. Apparently the dimmer died. It tripped the breaker whatever happened inside it. New dimmer now and everything is working.
Thanks to all!
A dead dimmer is much better than Gremlins!
Its very simple Averagesuprenova...
Hot wire goes through the dimmer to control the voltage, then it goes to the meter, then it goes to power the light bulb.
Neutral goes to the meter and then the light bulb.
I have to admit I was scratching my head Hutch. :oldconfused:
It's not so simple because it contradicts what you wrote in post #12. Your diagram shows the neutral NOT going to the dimmer. The diagram is how I would have expected it, not the way you worded it in the description.
You are correct Averagesupernova. 👍
I messed up royal on post 12. The dimmer only use's the hot wire.
  • · Replies 36 ·
  • Sticky
  • · Replies 705 ·
24
124K
83K
  • · Replies 57 ·
15K
