Equations and Tangents for Curve C at Point P
  • Thread starter Thread starter discombobulated
    Curve Gradient
The gradient of curve C is defined by the equation dy/dx = (3x-1)², with point P (1,4) on the curve. To find the normal at point P, the equation derived is 4y = -x + 17. For part b, the task is to integrate the derivative to find the original function, which involves integrating dy/dx to obtain y = x³ - x² + x + c, and using point P to determine the constant c. Part c requires demonstrating that no tangent to curve C is parallel to the line y = 1 - 2x by comparing gradients. It's essential to verify the integration by differentiating the result to ensure it matches the original derivative.
discombobulated
The gradient of the curve C is given by: dy/dx = (3x-1)2
the point P (1,4) lies on C.
a) Find an equation of the normal to C at P.
b) Find an equation for the curve C in the form y=f(x)
c) using dy/dx = (3x-1)2 show that there is no point on C at which the tangent is parallel to the line y=1-2x.
Well for a) i got: 4y= -x+17 (subbed x= 1 in dy/dx, got grad of normal and got eq)
But, i don't understand what part b) wants me to do. I think i could do c) by using the gradients and showing that they're not the same.
Some help on b) please!
You have the derivative of the function y=f(x). Do you know how to get the original function back from its derivative? Do you know why they said to "find an equation" instead of "find the equation" in b)?
do you mean i have to integrate dy/dx = (3x-1)2 for b)
to get : 3x3 - 3x2+x +c ?
Integration is the correct operation. But your answer is not correct yet. You should be able to check your answer by differentiating it again to get back to the original equation for dy/dx.
oh wait i remembered i need work out c, by using P(1,4)
Thanks for your help!
Your welcome. Be sure to do the step where you check your answer using differentiation.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
