Graphical Four Bar Linkage question
  • Context: Engineering
  • Thread starter Thread starter jojosg
10 replies · 2K views
jojosg
In a four-bar mechanism, the length of crank AB-15 mm, length of coupler BC-40 mm. length of rocker CD-30 mm, and length of frame DA=45 mm. Graphically determine the following.(1)The throw yof rocker CD,
(2)The maximum value of pressure angle a., and(3) The time ratio.
nil
Did I do mine correctly?
jojosg said:
Homework Statement: In a four-bar mechanism, the length of crank AB-15 mm, length of coupler BC-40 mm. length of rocker CD-30 mm, and length of frame DA=45 mm. Graphically determine the following.(1)The throw yof rocker CD,
Relevant Equations: nil
I find your diagram illegible. If I expand it at all it becomes very fuzzy.
I don’t fully understand your diagram. It looks like you have superimposed three states in one picture:
1. Joint B is down to the left from A, with AB and BC at 180° to each other.
2. Joint B has been rotated so that angle CAB is 180°-134°=46°.
3. Joint B is further rotated so that ABC form a straight line.
The throw, then, would be the change in angle of CD from position 1 to position 3.
So what is position 2 and where does the 134° come from? I see no basis for it in the question text.
I agree with your 55° (well, 54 point something).
I'm also not not sure about 134 degrees. I'm not sure how to measure pressure angle
haruspex said:
You must have written it for a reason. Where does it come from?
What do you mean by a "pressure angle"?
For the 134 degrees I drew the case where link AB and link BC are coincident and fold together. The I measured the angle between AB original position to the folded position which gives me 134 degrees. Maximum pressure angle occurs when the transmission angle is minimal, typically at extreme positions of the linkage. Thats what I think it is.
What original position? Are you basing that on a diagram provided with the question?
If so, I would think it is purely illustrative of a general position, not indicating any specific angles of interest.
What angle, or difference of two angles, do you consider to be the 'throw', and what value do you get for it?
After some research, it seems that the "transmission angle" is BCD in your diagram. I'm still unclear what the "maximum pressure angle" is, but I here assume it is a particular value of the transmission angle, namely, that which corresponds to maximum pressure somewhere.
You wrote that it corresponds to the minimum transmission angle, so if my assumption is correct it would be that minimum value.
However, my intuition is that it means an angle at which the maximum pressure is exerted on joint C, and that would be when ABC is a straight line, yes?
In the actual setup, it can go past straight, making the transmission angle smaller.
Can you provide a link where all these terms are defined?
Textbook This is the textbook I'm using for this course. The original position I refer to is based of the diagram provided.
It confirms that the position you measured the 134° from is purely illustrative. It is not relevant to the actual question. Just use the B'C' and B"C" positions.
I can’t find any description of pressure angle as it applies to a linkage.
For cams and gears it is defined as the angle between the pressure applied by the driver on the follower (which is normal to the contact plane) and the instantaneous direction of movement of the follower. But here we have two transfers: from AB to BC and from BC to CD. My guess is that it is angle between BC and the direction of movement of C. Note that the angle could be maximised after passing through position B"C", at which point it will be pulling on C, not pushing.
Reply
