Graphing Euler Relationship as exponential spiral
The discussion focuses on the Euler Relationship, expressed as e = cos(θ) + i sin(θ), and its graphical representation as an exponential spiral. Participants clarify that the right-hand side of the equation can be rewritten to show that e(a+bi) = ea * ebi, where ea represents a constant radius and ebi traces a circle in the complex plane. The calculations for converting inputs a and b into their corresponding x and y values are established as x = ea cos(b) and y = ea sin(b), providing clarity on how to visualize and compute points on the spiral.
  • Understanding of complex numbers and the complex plane
  • Familiarity with Euler's formula and its components
  • Basic knowledge of trigonometric functions: sine and cosine
  • Ability to perform exponential calculations
  • Explore the implications of Euler's formula in complex analysis
  • Learn about the graphical representation of complex functions
  • Study the properties of exponential spirals in mathematics
  • Practice calculating points on the complex plane using different values of a and b
Mathematicians, physics students, and anyone interested in complex analysis and visualizing mathematical concepts through graphical representations.
KeyLime
Hi everyone,
I am trying to get an intuitive grasp of the Euler Relationship
e^i(theta)=cos(theta)+i sin(theta)
and also understand how to graph the exponential spiral, as demonstrated on this web page:
http://www-math.mit.edu/daimp/ComplexExponential.html"
Ok, first the neuron stimulation.
I grasp how cos corresponds to the Real axis of the unit circle and sin is the imaginary axis. I grasp how to plot a complex number on the imaginary plane.
I don't grasp why cos(theta) + i sin(theta) gives me a point on the unit circle, when on a real plane I'd have to invoke Pythagoras: sqrt((cos(theta))^2 + (sin(theta))^2) = 1 to get a point on the circle.
Regarding the complex exponential tool at the link above, when I try to calculate the "a" and "b" calculations on the right side using the "a" and "b" selections on the left side, I get confused. For example, if I set b=0 and adjust a on the left, on the right side I get just e^a. This is obvious even to me. If I set a=0 and adjust b on the left, then on the right side, "a" is cos(left b) and "b" is sin(left b), so left-side b really is theta. I follow so far. How do I calculate the right-side a and b when the left-side a and b are not zero?
More fundamentally, how do you guys mentally picture what the function e^ix looks like? I want to picture a circle, but I'm not getting it. :frown:
Sigh.
Mathematics news on Phys.org
Well the reason why cos x + i sin x gives a point on the unit circle without using Pythagoras is because the planes are different :)
On the complex plane, the components of a number are sort of like directions. 1 + 2i means 1 to the right, then 2 up. or cos x to the right (if cos x is positive) and then sin x up or down. Hopefully that will help you visualize why e^ix is a circle.
Rewrite the right hand side, then it will become clearer:
Right hand side:
e^{(a+bi)} = e^a \cdot e^{bi}
Now if you look carefully at the expression you will notice that, e^a is just a real number and e^{bi} is a number on a circle in the complex plane.
(i) Now, let a be a constant, so e^a is also constant (choose for example a=0 as you mentioned):
e^a = K
Thus we can write: e^a \cdot e^{bi} = K \cdot e^{bi}
Let's examine the expression K \cdot e^{bi}.
How can we draw this in the complex plane?
If we change b only, then you will only move on the circle (with radius K) in the complex plane.
(ii) What happens, if you simultaneously change a and b?
Changing b results in a movement on the circle, but if you additionally
change a, you will also change K, the radius.
That is why you get a spiral because you also change the radius.
For example you could change a and b simultaneously by multiplying
both of them with a factor t:
(a+bi)t
To make this clearer, let's use the program on your website:
1. On the left hand side set a=0.25 and b=2.00
2. On the right hand side, there is this yellow "t-bar". Change the value
from 0 to 1.
- While changing t, observe the left hand side graphics. The yellow
dot moves from the red to the blue dot.
- While changing t, this time observe the right hand side graphics.
The yellow dot moves along the spiral from the red to the blue dot.
Gib Z - Thanks for the reply.
I did mention I understand how to plot a complex number on the plane - the way you said. And I have noticed that the complex plane is different than a real plane regarding applicability of Pythagoras' theorem. I have been stuck on the why is it different part. It's just occurred to me though, that comparing the complex plane and the real plane is not a valid comparison. A complex number is not two-dimensional like a point in an x/y plane is two dimensional. A complex number is (I think) one-dimensional; for example when a complex number has the imaginary portion = zero. Extending this thought, I should be able to plot a two dimensional point where x and y are complex numbers. Perhaps I can graph the point using one Real plot with real X and Y axes and one Imaginary plot with imaginary X and Y axes. Anybody hear of such a thing?
Edgardo - Thanks for your reply too.
The part where you set e^a to K was interesting. As you said, setting left a to zero (K=1) does result in left b moving a point on the circle on the graph at the right. However, setting left a to, say, 0.1 (K=1.105) results in left b moving a point on a spiral, even though left a is fixed (constant). So the radius isn't just K.
Part of what I'm trying to figure out is how to actually calculate the right a and b values. For example, if I set left a to 0.25 and left b to 1.23, I end up with right a = 0.42 and right b = 1.21. So far my feeble calculations produce different values.
If anybody else can add more thoughts, great. Otherwise, I'll post follow-ups if I find out any further answers.
Keep "a" constant at a=0.1 and change "b".
While varying "b" observe the blue dot on the right screen.
You'll notice that the dot moves on the blue circle and
not in a spiral.
Let's introduce a new notation. Instead of saying "left a and b values" and
"right a and b values", we say:
Left hand side: a+bi
Right hand side: x+yi
So your question is, how will x and y look like, if you have a and b as input.
In your example, you set a=0.25 and b=1.23,
and you end up with x=0.42 and y=1.21
Let us review again how the calculation is done.
You have a+bi as input and on the right hand side you get e^{a+bi}.
But we want to know x and y:
You have a+bi as input and on the right hand side you get x+yi.
So the question is, how do x and y look like. Well, let's just
manipulate e^{a+bi} until we get it to the form x+yi.
e^{a+bi} = e^a e^{bi} = e^a (\mbox{cos}(b) + i \mbox{sin}(b)) = (e^a \mbox{cos} (b)) + i (e^a \mbox{sin} (b)) = x + yi
Thus, by comparing the last equation
we get
x = e^a \mbox{cos}(b) and
y = e^a \mbox{sin}(b)
Let's check this with the values from your example:
a = 0.25 and b = 1.23 yields
x = e^{0.25} \mbox{cos}(1.23) = 0.43
y = e^{0.25} \mbox{sin}(1.23) = 1.21
(Don't forget to set "rad" instead of "deg" on your calculator).
You've done it! Somehow I wasn't seeing the blue circle for what it is, namely e^a, like you said the first time. It never occurred to me to substitute the imaginary portion of e^(a+ib) with the full Euler's relationship like you did :bugeye:. Understanding the calculations that produce the graph on the right is the key I needed to understand the equation.
Thank you very much.
