Graphing Euler Relationship as exponential spiral
KeyLime
Hi everyone,
I am trying to get an intuitive grasp of the Euler Relationship
e^i(theta)=cos(theta)+i sin(theta)
and also understand how to graph the exponential spiral, as demonstrated on this web page:
http://www-math.mit.edu/daimp/ComplexExponential.html"
Ok, first the neuron stimulation.
I grasp how cos corresponds to the Real axis of the unit circle and sin is the imaginary axis. I grasp how to plot a complex number on the imaginary plane.
I don't grasp why cos(theta) + i sin(theta) gives me a point on the unit circle, when on a real plane I'd have to invoke Pythagoras: sqrt((cos(theta))^2 + (sin(theta))^2) = 1 to get a point on the circle.
Regarding the complex exponential tool at the link above, when I try to calculate the "a" and "b" calculations on the right side using the "a" and "b" selections on the left side, I get confused. For example, if I set b=0 and adjust a on the left, on the right side I get just e^a. This is obvious even to me. If I set a=0 and adjust b on the left, then on the right side, "a" is cos(left b) and "b" is sin(left b), so left-side b really is theta. I follow so far. How do I calculate the right-side a and b when the left-side a and b are not zero?
More fundamentally, how do you guys mentally picture what the function e^ix looks like? I want to picture a circle, but I'm not getting it. :frown:
Sigh.
Mathematics news on Phys.org
Well the reason why cos x + i sin x gives a point on the unit circle without using Pythagoras is because the planes are different :)
On the complex plane, the components of a number are sort of like directions. 1 + 2i means 1 to the right, then 2 up. or cos x to the right (if cos x is positive) and then sin x up or down. Hopefully that will help you visualize why e^ix is a circle.
Rewrite the right hand side, then it will become clearer:
Right hand side:
e^{(a+bi)} = e^a \cdot e^{bi}
Now if you look carefully at the expression you will notice that, e^a is just a real number and e^{bi} is a number on a circle in the complex plane.
(i) Now, let a be a constant, so e^a is also constant (choose for example a=0 as you mentioned):
e^a = K
Thus we can write: e^a \cdot e^{bi} = K \cdot e^{bi}
Let's examine the expression K \cdot e^{bi}.
How can we draw this in the complex plane?
If we change b only, then you will only move on the circle (with radius K) in the complex plane.
(ii) What happens, if you simultaneously change a and b?
Changing b results in a movement on the circle, but if you additionally
change a, you will also change K, the radius.
That is why you get a spiral because you also change the radius.
For example you could change a and b simultaneously by multiplying
both of them with a factor t:
(a+bi)t
To make this clearer, let's use the program on your website:
1. On the left hand side set a=0.25 and b=2.00
2. On the right hand side, there is this yellow "t-bar". Change the value
from 0 to 1.
- While changing t, observe the left hand side graphics. The yellow
dot moves from the red to the blue dot.
- While changing t, this time observe the right hand side graphics.
The yellow dot moves along the spiral from the red to the blue dot.
Gib Z - Thanks for the reply.
I did mention I understand how to plot a complex number on the plane - the way you said. And I have noticed that the complex plane is different than a real plane regarding applicability of Pythagoras' theorem. I have been stuck on the why is it different part. It's just occurred to me though, that comparing the complex plane and the real plane is not a valid comparison. A complex number is not two-dimensional like a point in an x/y plane is two dimensional. A complex number is (I think) one-dimensional; for example when a complex number has the imaginary portion = zero. Extending this thought, I should be able to plot a two dimensional point where x and y are complex numbers. Perhaps I can graph the point using one Real plot with real X and Y axes and one Imaginary plot with imaginary X and Y axes. Anybody hear of such a thing?
Edgardo - Thanks for your reply too.
The part where you set e^a to K was interesting. As you said, setting left a to zero (K=1) does result in left b moving a point on the circle on the graph at the right. However, setting left a to, say, 0.1 (K=1.105) results in left b moving a point on a spiral, even though left a is fixed (constant). So the radius isn't just K.
Part of what I'm trying to figure out is how to actually calculate the right a and b values. For example, if I set left a to 0.25 and left b to 1.23, I end up with right a = 0.42 and right b = 1.21. So far my feeble calculations produce different values.
If anybody else can add more thoughts, great. Otherwise, I'll post follow-ups if I find out any further answers.
Keep "a" constant at a=0.1 and change "b".
While varying "b" observe the blue dot on the right screen.
You'll notice that the dot moves on the blue circle and
not in a spiral.
Let's introduce a new notation. Instead of saying "left a and b values" and
"right a and b values", we say:
Left hand side: a+bi
Right hand side: x+yi
So your question is, how will x and y look like, if you have a and b as input.
In your example, you set a=0.25 and b=1.23,
and you end up with x=0.42 and y=1.21
Let us review again how the calculation is done.
You have a+bi as input and on the right hand side you get e^{a+bi}.
But we want to know x and y:
You have a+bi as input and on the right hand side you get x+yi.
So the question is, how do x and y look like. Well, let's just
manipulate e^{a+bi} until we get it to the form x+yi.
e^{a+bi} = e^a e^{bi} = e^a (\mbox{cos}(b) + i \mbox{sin}(b)) = (e^a \mbox{cos} (b)) + i (e^a \mbox{sin} (b)) = x + yi
Thus, by comparing the last equation
we get
x = e^a \mbox{cos}(b) and
y = e^a \mbox{sin}(b)
Let's check this with the values from your example:
a = 0.25 and b = 1.23 yields
x = e^{0.25} \mbox{cos}(1.23) = 0.43
y = e^{0.25} \mbox{sin}(1.23) = 1.21
(Don't forget to set "rad" instead of "deg" on your calculator).
You've done it! Somehow I wasn't seeing the blue circle for what it is, namely e^a, like you said the first time. It never occurred to me to substitute the imaginary portion of e^(a+ib) with the full Euler's relationship like you did :bugeye:. Understanding the calculations that produce the graph on the right is the key I needed to understand the equation.
Thank you very much.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
