Gravitation Field Problem With Equal Masses
  • Thread starter Thread starter hardygirl989
    Field Gravitation
The problem involves calculating the gravitational field at the fourth corner of a square formed by three equal masses located at the other corners. The gravitational field strength from the diagonal mass is calculated as GM/(l√2)^2, while the combined field from the two adjacent masses is GM√2/l^2. The total gravitational field magnitude is GM/(2l^2) + GM√(2)/l^2. For direction, the symmetry of the configuration suggests it points at a 45-degree angle. The discussion confirms that the approach to finding the direction is correct based on the symmetry of the setup.
hardygirl989
Three objects of equal mass (m) are located at three corners of a square of edge length , as shown in the figure below. Find the magnitude and direction of the gravitational field at the fourth corner due to these objects. (Use any variable or symbol stated above along with the following as necessary: G.)
Image: http://www.webassign.net/serpse8/13-p-025.gif
The magnitude of the gravitational field is
= GM/R^2 with R = l, and G = gravitation constant, M = mass
The field strength of the diagonal mass = GM/(l*√2)^2
and the sum of the field magnitudes from the two neighbored masses is GM*√2/l^2.
So the total magnitude = GM/(2l^2) + GM√(2)/l^2
For the direction, I am not sure what it would be...Would it be 45 degrees or do I need to derive a new formula? If so, how should I go about creating the formula? Thanks!
hi hardygirl989! :smile:
yes of course :smile:
the figure is obviously symmetric about that direction (which is why you chose to calculate the components in that direction :wink:)
