Gravity does not significantly affect how magnets interact with each other under normal conditions. The magnetic force between magnets is much stronger than the gravitational force at atomic and molecular levels. While extreme gravitational fields could potentially alter the properties of a magnet, typical gravitational variations, such as those found on Jupiter, do not impact magnetism. Current understanding suggests that there is no direct relationship between gravitational fields and magnetic fields. Research continues in the pursuit of a Unified Field Theory, but no significant effects of gravity on magnetism have been established.
#1
Nile3
42
Does gravity affect the way magnets interact with one another? Would the same magnet be stronger in a low gravitational field (just empty space) compared to let's say jupiter?
Nile3, gravity, if we are talking about pure static gravity of normal strengths, does not significantly affect the way magnets interact with one another. The force on one magnet is the linear superposition of the local gravitational force and the magnetic force from the other magnet. On the atomic and molecular levels--and ferromagnetic phenomena are atomic or molecular level phenomena--gravitational forces that are normally encountered are negligible compared to electromagnetic forces, and so we expect no interaction. If the gravitational field were strong enough to compress the source magnetic enough to significantly change the distance between the ferromagnetic atoms in the source magnet, the source magnet could cease to be ferromagnetic, but I am assuming here that the gravity field is not that strong. Physicists are seeking a Unified Field Theory that could reveal presently unknown relationships between the different fields, but we presently know of no way that a gravitational field can directly create or significantly affect a magnetic field.
I'm thinking about the following problem. I have an electrified fluid with a constant charge density, Q, within the fluid. Will this necessarily yield a surface charge?
Would I have to compute it by looking at the displacement fields on either side of the interface? Would it change if the bulk charge within the fluid remains constant?
This is from Griffiths' Electrodynamics, 3rd edition, page 352.
I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##.
In matrix form, this tensor should look like this...
Please can anyone either:-
(1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges?
Or alternatively (2) point out where I have gone wrong in my method?
I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula.
Here is my method and results so far:-
This...
