Gravitational potential energy confusion
Gravitational potential energy (GPE) can be confusing due to its dependence on distance, as highlighted by two equations: GPE = -mgh for near-body scenarios and GPE = -G*M*m/R for distant bodies. The first equation suggests GPE increases with height, while the second indicates it decreases with increasing distance, leading to confusion. However, the key distinction lies in understanding that as height increases in both cases, the absolute value of GPE increases, even if the equations appear to suggest otherwise. The minus sign in the equations indicates the direction of force, not the energy's behavior with distance. Clarifying these concepts resolves the confusion surrounding gravitational potential energy.
sciencegem
Hi,
I've managed to get myself confused over the simplest thing. Intuitively I'd think that gravitational potential energy is proportional to distance as described by the near-body equation GPE=-mgh. The alternative for farther bodies (-G*M*m/R) has me confused because it is inversely proportional to distance. In other words (the way I see it) GPE grows the "higher up you go" with one equation while it shrinks perplexingly with the other. I know I'm probably just missing something so basic it's pathetic, I'm very frustrated with myself over this. Any hints on how to resolve my mental dilemma are appreciated.
Thanks!
You are probably missing the minus sign.
I'm not. What I mean is, say, -m*g*.01 is small whereas -G*M*m/.01 is big.
Have you taken Calculus? The "potential energy" is the integral of the force function with respect to distance (conversely, the force is the derivative of the potential energy). The integral of x^n dx, for any constant x, is x^{n+1}/(n+1).
For movement close to the earth, where the force can be taken to be constant, the integral is just the \int -mg dx= -mgx, taking the "n" above to be 0 so that n+ 1= 1. But if we are talking about greater distances where we have to use the more general -GmM/r^2, we have n= -2 so that n+1= -1 and the integral is Gmm/r.
Likes 1 person
Are they?
What is g equal to in terms of G and M.
Substitute that in your GPE=-mgh equationm.
Likes 1 person
That is exactly what you are missing. It is NOT -mgh, it is +mgh. As h increases mgh increases. As r increases -GMm/r also increases (-4 is greater than -4000). They both increase as height increases.
Likes 1 person
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
