Gravitational Potential Energy of a particle
The discussion revolves around calculating the change in gravitational potential energy (U) of a four-particle system as the distance between them is reduced from 0.700 m to 0.100 m. The user initially computed U for both distances, obtaining values of U_1 at -6.45898846e-12 and U_2 at -2.60012192e-11. They calculated the change in U as 1.95422308e-11 but initially believed it to be incorrect. Ultimately, the user resolved their confusion and confirmed their calculations. The thread highlights the importance of careful computation in gravitational potential energy problems.
peaceandlove
Four particles, each of mass 60.0 g, form a square with an edge length of d = 0.700 m. If d is reduced to 0.100 m, what is the change in the gravitational potential energy of the four-particle system?
U = -GMm/r
I found the U of the system when d = 0.700 m and then I found the U when d = 0.100 m. Using those two values, I found what I believe to be the change in the U of the system. However, I keep getting the wrong answer.
U_1=-6.45898846e-12
U_2=-2.60012192e-11
(delta)U=1.95422308e-11
Nevermind, I figured it out.
