Gravitational Potential Energy of an object
The discussion centers on calculating the gravitational potential energy of a 1000 kg object influenced by a large uniform ring with a mass of 2.36x10^20 kg and a radius of 1.00x10^8 m. The initial potential energy was incorrectly calculated using the distance from the center of the ring instead of the distance to the ring's mass. Correcting this involves treating the scenario as a right triangle to find the appropriate distance. After adjusting the calculations, the correct potential energy values can be derived. The conversation highlights the importance of accurately determining distances in gravitational calculations.
mickellowery
Consider a large uniform ring having a mass of 2.36x1020kg and a radius 1.00x108m. An object with a mass of 1000kg is placed at a point 2.00x108m from the center of the ring. When the object is released, the attraction of the ring makes the object move along a straight line toward the center of the ring. Calculate the gravitational potential energy of the object-ring system when the object is at the starting point, and then calculate the potential energy at the ending point. Calculate the object's speed as it passes through B.
U= -Gm1m2/r
I used this equation for the initial condition with G=6.673x10-11 m1=2.36x1020 m2=1000 and r=2.00x108. The answer I got was -7.87x104. The book says that the answer is -7.04x104, I am assuming that I need to factor in the radius of the ring somehow but I don't know how I should work it into the equation.
You're using the wrong distance. You need the distance between the object and the ring (where the mass is), not between the object and the center of the ring.
Aaaahh I see, treat it like a right triangle and then use this equation. You've saved my sanity one more time Doc. Thanks so much.
