Gravitational potential of a point within a hollow sphere
The discussion revolves around the gravitational potential of a point mass located inside a hollow sphere. Participants explore the implications of gravitational forces and potential energy in this context, addressing theoretical concepts and mathematical formulations.
  • Some participants assert that an object inside a hollow sphere experiences no gravitational force, leading to questions about its gravitational potential energy.
  • Others argue that while the gravitational force is zero, the gravitational potential energy may still be constant but not necessarily zero.
  • A participant questions how potential energy can be zero if it is defined by a negative value, suggesting confusion over the summation of negative contributions.
  • There are discussions about the need to consider the direction of forces and whether potential energy, being a scalar, can be summed without vector considerations.
  • Some participants propose that the gravitational potential energy from a hollow sphere is zero for a spherical object, assuming it is outside the sphere.
  • One participant mentions that the escape velocity inside a hollow sphere is the same as that on its surface, indicating a perspective on gravitational potential.
  • Concerns are raised about the gravitational effect of external objects on those inside the hollow sphere, with some suggesting it would be as if the hollow sphere were not present.
  • There is a discussion about the integral sum of potential contributions from multiple mass elements and how it relates to the independence of position within the sphere.
Participants express differing views on the nature of gravitational potential energy within a hollow sphere, with no consensus reached on whether it can be considered zero or constant. The discussion remains unresolved regarding the implications of external gravitational influences on objects inside the sphere.
Some participants highlight the importance of defining reference points for gravitational potential and the arbitrary nature of the zero point in classical mechanics. Additionally, there are unresolved mathematical steps regarding the summation of potential contributions from multiple sources.
  • #31
pervect said:
You may be interested in not the potential, but the gravitational self-energy aka gravitational binding energy of the shell. That would be the amount of energy needed to disassemble the shell.
(If you're not, just skip this part below).
If you imagine pulling the shell apart, you can see that you would need to apply a force (GMdm/r^2) to every mass element dm, from r to infinity.
As the shell expands, the force equation won't change - to calculatse the required force, you can still use the simplification that the force is the same as if all the mass were at the center of the shell.
This intergal gives a binding energy of GM^2/r for a uniform shell.
Contrast this to a sphere, where the binding energy is (3/5)GM^2/r
http://en.wikipedia.org/wiki/Gravitational_binding_energy
The binding energy of a sphere is not just the sum of the binding energies of its shells, because the shells interact with each other.
This is what I've been trying to calculate, because the derivation I saw didn't make any sense to me. Here's what I saw:
http://scienceworld.wolfram.com/physics/SphereGravitationalPotentialEnergy.html
What they're doing is taking a spherical shell of radius r, thickness r+dr, and calculating the potential between that spherical shell and all the mass containing within the shell. What *I* don't get is why can they ignore all the mass outside the shell, and why can they ignore the potential energy due to the interactions of the mass that lies *on* the shell.
I've been trying to do it without somebody just giving me the answer, which is why I didn't ask what the self-binding energy was outright :)
EDIT: Also, in pulling the shell apart, how can it be GMdm/r^2, as all the little bits that make up M are not equi-distance from dm. I also don't see how you can simplify things by saying you can concentrate all the mass at the center of the shell, since we're trying to calculate the force *on* the shell, due to the other parts of the shell, not inside or outside of it.
  • #32
Take a spherical mass. The amount of energy required to remove any small piece of the mass from its surface to infinity will be
E = G*M*dm/r
where r is the distance of the piece of the mass element dm from the center.
This comes from the gravitational potential of a sphere.
Now, to remove a thin spherical shell, the energy required is just
E = G*Mencl*(rho*4*Pi*r^2*dr)/r
from the above formula. This works because the shell is so thin that it doesn't have any significant self energy. (Can you see why the self energy of just the shell is on the order dm^2 when the shell is small, while the energy due to the shell coupling to the rest of the mass is of the order M*dm?)
Mencl is the mass of the enclosed sphere, which is just
Mencl = rho*(4/3)*Pi*r^3
We make r vary downard from R to 0, R being the radius of the mass. As we peel away each layer of the sphere, Mencl drops.Put this all together, mash it around, do the intergal, and you should get the desired result, after back-substituing for the total mass M in terms of density, rho, and radius, R.
  • #33
Ah, now I understand. A much better explanation. I thought that perhaps you could say the that due to the thinness of the shell it doesn't have any significant self-energy, but it makes much more sense because the self energy of the shell will be on the order of dm^2. Thank you.
  • · Replies 46 ·
  • · Replies 27 ·
12K
  • · Replies 29 ·
