Gravitational time dilation calculation near a Black Hole
The discussion centers around the calculation of gravitational time dilation near the supermassive black hole Sgr A* in the Galactic Center, exploring both theoretical and practical aspects of the phenomenon as described by Einstein's Theory of General Relativity. Participants examine the implications of different scenarios, such as an observer hovering versus one in circular orbit, and the effects of black hole rotation on time dilation calculations.
  • Exploratory, Technical explanation, Debate/contested
  • One participant presents a formula for calculating time distortion near a black hole and attempts to apply it to Sgr A*, calculating a specific distance from the event horizon.
  • Another participant corrects the formula and notes that it applies only to a hovering observer, suggesting that a more realistic scenario involves an observer in circular orbit.
  • There is a discussion on whether to include the effects of relative velocity for an observer in circular motion, with references to different formulas for time dilation in such cases.
  • Participants mention that free-fall circular orbits are only possible outside a certain radius and that those orbits are unstable until reaching another specified radius.
  • There is a note that the formulas discussed apply to non-rotating black holes, with questions raised about the rotation of Sgr A* and its significance for the calculations.
  • One participant expresses uncertainty about whether Sgr A* can be treated as a non-rotating black hole for the purposes of applying the discussed formulas.
Participants generally agree that the time dilation calculations differ based on the observer's position and motion relative to the black hole. However, there is no consensus on the significance of Sgr A*'s rotation and its impact on the validity of the formulas being discussed.
Limitations include the dependency on the assumption of a non-rotating black hole and the unresolved nature of Sgr A*'s actual rotation rate, which may affect the applicability of the discussed formulas.
Antonio
Hello to everyone!
I am trying to understand in practice the Gravitational Time Dilation by calculating the time distortion near the supermassive black hole Sgr A* in our Galactic Center.
According to Einstein's Theory of General Relativity, the time distortion near a black hole is calculated with the following formula:
T^2 = t^2 / 1 - ( Rs / r ), where:
T= Observer A time, far away from the black hole
t = Observer B close to the black hole
r = Distance between the black hole and Observer B
Rs= Schwarzschild Radius
For the Sgr A* black hole I found that the Schwarzschild Radius is Rs=13 * 10^16 km. Based on that, I tried to calculate how close to the Event Horizon of the black hole does Observer B have to be so that Observer A sees 60 seconds pass for every 12 seconds on Observer B clock. I calculated that the distance should be r=541.666,67 km
Could you tell me please if my reasoning is correct and if not what is the proper answer?
Thank you in advance!
T^2 = t^2 / 1 - ( Rs - r ), where:
That's not quite right. It should be:
[itex]T^2 = t^2 \frac{1}{1-(R_s/r)}[/itex]
But actually, that formula is only valid for a special case: when Observer B is hovering in place outside the black hole. A more realistic case would be for observer B to be traveling in a circular orbit around the black hole.
Initially, thank you very much for your answer. I am really sorry, I made a typo in the formula, which I have just corrected it.
  1. So the distance from the event horizon [ r=541.666,67 km ] that I have calculated is true only for a hypothetical scenario in which the Observer B is hovering in place outside the black hole.
  2. In order to calculate a more realistic case, in which the Observer B is traveling in a circular orbit around the black hole should I calculate also the time distortion due to the relative velocity?
There's more to it than that because the gravitational time dilation is different for a hovering observer and one in a freefall orbit (as you would expect, because they are following very different paths through spacetime). The wikipedia page on "Gravitational time dilation" has the formula you need, and then you will have to add the effects of relative velocity on top of that.
Yes, but in Schwarzschild coordinates, the time-dilation effect of tangential motion (constant [itex]r[/itex]) is different from that of radial motion.
For circular motion, we have:
[itex]dt^2 = [(1-R_s/r) - r^2 \dot{\phi}^2] dT^2[/itex]
where [itex]\dot{\phi}[/itex] is the angular velocity, as measured in terms of the time variable [itex]T[/itex].
It is worth noting, though, that free-fall circular orbits are only possible outside ##r = 3M## (3/2 the Schwarzschild radius), and those orbits are unstable until you get outside ##r = 6M## (3 times the Schwarzschild radius). The formula for time dilation in a free-fall circular orbit is
T = \frac{t}{\sqrt{1 - \frac{3}{2} \frac{R_s}{r}}}
The orbital velocity doesn't appear directly because for a free-fall orbit it has a fixed relationship to ##R_s## and ##r##.
It's also worth noting that all of the formulas we are discussing are for a non-rotating black hole. AFAIK the hole at the center of our galaxy is not rotating (or at least not significantly).
PeterDonis said:
It's also worth noting that all of the formulas we are discussing are for a non-rotating black hole. AFAIK the hole at the centre of our galaxy is not rotating (or at least not significantly).
Thank you all for the very informative answers.
Finally and after exploring your comments, I have understood much better the way that time distorts near a black hole. Especially, the Wikipedia page on "Gravitational Time Dilation" includes all the necessary formulas regarding the time dilation for an Observer either in a "hovering situation" - rest frame or in a Circular Orbit.
However, the only unclear point to me now is whether the Sgr A* Black Hole is indeed a non-rotating black hole and if we can use these formulas. After a search on the Web, I found that Sgr A* Black Hole is rotating, but I couldn't find if its rotation is significant or not regarding the application of these formulas.
So, can we assume that Sgr A* Black Hole is a non-rotating spherical body and finally to apply these formulas for simple Gravitational Time Dilation calculations? Or our results would be completely wrong if the rotation of the Sgr A* Black Hole is significant?
Thank you.
If the rotation is significant, the correct formulas would be different (and more complicated).
I don't know how much information we have on the actual rotation rate of the Sgr A black hole.
  • · Replies 40 ·
  • · Replies 29 ·
  • · Replies 35 ·
  • · Replies 16 ·
  • · Replies 51 ·
  • · Replies 51 ·
  • · Replies 20 ·
