Gravity at its maximum range question.
The discussion centers on the nature of gravity and its range in a hypothetical universe with two massive bodies at opposite ends. It is established that Newtonian gravity extends infinitely, becoming weaker with distance but never truly reaching zero. The conversation also touches on the concept of space-time, noting that it can asymptotically flatten out in systems with isolated bodies. Additionally, there is confusion about how gravity can have infinite range while space-time does not, leading to a clarification that gravity's influence diminishes with distance, similar to how space-time curvature approaches flatness at infinity. Overall, the relationship between gravity, space-time curvature, and their respective ranges is explored.
solar71
Hey guys. I have an unusual question.
Lets say the universe is 100,000,000,000 Light years across. (100 billion I think)
Lets say there are only 2 bodies that have mass in said universe.
One body is at one end of this universe and the other body is at the opposite end.
Do these 2 bodies pull on each other? Does gravity have a finite range?
Or does gravity have infinite range but only gets infinitely weaker with distance?
Does space/time eventually flatten out?
Thanks
The Newtonian gravitational field extends out to infinity in all directions and only goes to zero at infinity. As for space-time eventually flattening out, if you have a system consisting of isolated bodies (bodies that are always localized to some fixed region of space) then yes space-time will eventually flatten out (such space-times are called asymptotically flat).
Ok thanks for your well informed reply. Much appreciated.
One more question. I was under the impression that the bending of space and therefor time is what caused gravity to act on objects. So how is it possible for gravity to have infinite range but space/time not to?
Doesn't space have to be slightly bent for gravity to be present? And if gravity has infinite range doesn't that mean that the bending of space also has infinite range as well? And if so doesn't that mean that time is also slightly bent/stretched as well?
I'm a little confused. Please enlighten me.
Thanks
Consider for example an isolated stationary star. The space-time curvature produced by the star asymptotically becomes flat meaning it approaches flat space-time as you approach spatial infinity. So in this sense it is exactly like the Newtonian gravitational field which itself approaches zero as you approach spatial infinity. Sorry if that wasn't clear before; I wasn't implying that the Newtonian gravitational field is non-zero everywhere, I was implying that it asymptotically approached zero as you approach spatial infinity.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
