Gravity Waves from Earth: Detecting from Orbit
Atlas3
Could we detect Earth gravity wave from Earth orbit?
The answer to both questions is "no".
My astronomy professor says you and me exert a gravitational force on each other from across the room. It may be very weak and we don't pull together but because of mass it's there. His words.
That is true, but it also is completely irrelevant to the question that you asked in the first post and Vanadium 50's correct answer to that question. You might want to stop for a moment and consider how we would detect the gravitational force between you and your professor (it's there, and if you google for "Eotvos gravity measurement" you'll see how we can measure it)... then consider whether this would work from Earth orbit because that was your original question. And in any case the force between two masses has nothing whatsoever to do with gravitational waves.
This thread is closed, but you can start a new thread with a more specific question when you're ready.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
