Gravity's Impact: Comparing Ball A and B
  • Thread starter Thread starter zizodev
    Ball Impact
When comparing two balls of the same size and material, one filled with air (Ball A) and the other with water (Ball B), the discussion centers on which will hit the ground first when dropped from 100 feet. The initial suggestion is that Ball B will land first due to the higher density of water compared to air. However, the conversation highlights the need for a quantitative analysis, questioning the pressure of the air inside Ball A as a factor. The impact of air resistance and the density of the materials are critical to understanding the outcome. Ultimately, the discussion emphasizes the importance of considering both density and air pressure in determining the result.
zizodev
consider two balls of exactly the same size and material.
Ball A is filled with air and ball B is filled with water.if dropped from a height of 100 feet,which will hit the ground first?
U=mgh.
i suggest the ball B will hit the ground first because the water is more denser than air.
U=mgh.
Nice hunch, but can you supply a quantitative reason?
yes PeterO we didn't know how that air in the ball is it in high pressor or not :)
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 31 ·
