How Can You Solve for Non-Integral Solutions of the Greatest Integer Function?
  • Thread starter Thread starter sadhu
    Function Integer
The discussion focuses on solving the equation [x][y] = x + y, where [x] represents the greatest integer function. The integer solutions identified are (0, 0) and (2, 2). Participants clarify that for integer values, the equation simplifies to xy = x + y, leading to the conclusion that x must equal 2 or 0. Further exploration of non-integral solutions is suggested, but participants express difficulty in progressing beyond the initial findings. The conversation highlights the importance of systematic approaches over guessing in mathematical problem-solving.
sadhu
can anyone tell me how to solve for integer solutions of
[x]*[y]=x+y
tell the interval of its non integral solutions
pleazzzzzzzzzzzzzzzzzz...
Mathematics news on Phys.org
But [x] = x for all integers x, so the integer solutions of [x][y] = x + y are the same as the integer solutions of xy = x + y, (x, y) in {(0, 0), (2, 2)}.
well can you show the step
the answer is (0,0) ,(2,2)
i am looking for good and proper stepwise answer and not guesses , i think my method is very weak ..thats why i am here
first, I must say that "Guessing" (and then checking your guess) is a perfectly "good and proper" method! For n an integer, [n]= n so your equation is simply xy= x+ y. You can write this as xy- y= (x-1)y= x or, if x is not 1, y= x/(x-1). If x is not 0, that says x-1 divides x. The only integer x such that x-1 is a factor of x, is x= 2. You can then check x= 1 or x= 0 separately: If x= 1, xy= x+ y becomes y= 1+ y which is never true.; If x= 0, then xy= x+ y becomes 0= 0+ y which is true for y= 0. The only only solutions are x= y= 0 and x= y= 2.
i agree to what you said
if you replace x-1=k
y=1+1/k
case 1
k>=1
y=2
no further value of k will do as 1/k is a fraction and goes on to decrease
similiarly you can do k<1
k=-1
y=0
rest all give fraction of decreasing value
ok this much is clear to me but i can't even think of something to start with for next part
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
