Green's function for a critically damped oscillator
The forum discussion focuses on deriving the Green's function for a critically damped harmonic oscillator described by the equation \(\ddot{x} + 2\gamma\dot{x} + \omega_{0}^2 x = \delta(t-t')\). Participants clarify that the Green's function \(G(t,t')\) can be found by solving the second-order ordinary differential equation (ODE) with the Dirac delta function as the driving force. The integration process involves using Fourier transforms and complex analysis, particularly the residue theorem, to evaluate the integral, which is essential for determining the Green's function. The discussion also emphasizes the importance of boundary conditions in matching solutions across different time intervals.
  • Understanding of second-order ordinary differential equations (ODEs)
  • Familiarity with Fourier transforms and their applications
  • Basic knowledge of complex analysis, particularly the residue theorem
  • Concept of Green's functions in differential equations
  • Study the application of Green's functions in solving differential equations
  • Learn about the residue theorem in complex analysis
  • Explore the properties and applications of critically damped harmonic oscillators
  • Practice solving second-order ODEs with boundary conditions
Students and researchers in physics and engineering, particularly those studying dynamics, control systems, or mathematical methods in physics, will benefit from this discussion.
shyta
Consider critically damped harmonic oscillator, driven by a force F(t)
Find the green's function G(t,t') such that x(t) = ∫ dt' G(t,t')F(t') from 0 to T solves the equation of motion with x(0) =0 and x(T) =0
Hi guys, I am completely new to green's function.. need a lot of help understanding the use, and how to use it >_<
I've been doing some readings and this is what i understand so far
x = x _{h} + ∫G(t,t')f(t') dt'
i.e. G(t,t') will be the particular solution to the ode with F(t) = δ(t-t')
does this mean that I should let \ddot{x} +2γ\dot{x} + ω _{0}² = δ(t-t') and solve this to get the green's function?
Yes. Except that there's a small typo in your expression. It should be
\ddot{x} +2\gamma\dot{x} + \omega_{0}^2 x = \delta(t-t^\prime)
A nice way to solve the above equation is to write the RHS as the inverse of a Fourier transform, meaning the RHS becomes a harmonic function of time.
Hello! thanks for you reply! :)
yeah you are right, i missed out the x there
not sure if i got it right but on the RHS, i got \frac{1}{2\pi}\frac{1}{i(t-t&#039;)}e^{i\omega(t-t&#039;)}+C
is this right?
oh and (d²/dt² + 2γd/dt + ω0²) G(t,t') = δ(t-t')
so i should be solving as usual 2nd order ode to get my answer for homogeneous and inhomo am i doing the steps right?
is this right?
Try taking the Fourier transform of both sides. To makes things simpler, recognize that the dependent of t and t' in G has this form: G(t, t^\prime) = G(t - t^\prime)
im really bad at Fourier transform, so i didnt follow your advice..
but i did try considering the force being written as a Fourier transform
f(t) = 1/2\pi∫F(w)e^{iwt} dw
and the dirac delta
δ(t-t')= 1/2\pi∫ e^{iwt}e^{-iwt&#039;} dw
so i went ahead to solve and i got that
G(t,t') = x_{h} + 1/2\pi ∫ (e^{iwt}e^{-iwt&#039;}) / (-\omega^{2} + 2i\gamma\omega + \omega_{0}^{2}) dw
and I am stuck at this integration lol
and the dirac delta
The integration is a little tricky. You're going to need to use complex analysis, which I'm assuming you've at least met. Since we are dealing with a critically damped oscillator, we can set \gamma=1. What we're going to do now is extend the integral into the complex plane. Let C\subset\mathbb{C} be a semi-circle in the upper half plane, that is, C=\{\omega:|\omega|&lt; a, \omega\geq0\}. So, we have
I=\int_C \frac{e^{i\omega(t-t^\prime)}}{-\omega^2 + 2i\omega_0\omega + \omega_0^2}\;\text{d}\omega
Can you do the next step, maybe using Cauchy's Residue Theorem?
Hmm nope I have never heard of the residue theorem. I tried wiki-ing it to see how it works, but it looks complicated. Is there any other way to do this?
I can't immediately see another straightforward method to evaluate the integral. Let me ask a few of the other homework helpers and get back to you.
The differential equation for the damped harmonic oscillator is usually
\ddot{x} + 2\zeta\omega_0 \dot{x} + \omega_0^2x = 0There's a factor of \omega_0 in the damping term, and with this convention, a critically damped oscillator would correspond to \zeta=1, so I think you actually want \zeta=\omega_0 here.
Good catch! I didn't notice that :redfaced:
I will correct my earlier posts.
Another way to find the Green's function is to solve the differential equation in the two regions 0≤t<t' and t'<t≤T. Apply the boundary conditions, and then match the two solutions at t=t'. The Green's function needs to be continuous at the boundary, but its derivative is not. By integrating the differential equation from t'-ε to t'+ε and letting ε→0, you can find the discontinuity in the derivative.
  • · Replies 16 ·
