Understanding Green's Identity: Solving Laplace Equation for Harmonic Functions
  • Thread starter Thread starter yungman
    Identity
yungman
Harmonic function satisfies Laplace equation and have continuous 1st and 2nd partial derivatives. Laplace equation is \nabla^2 u=0.
Using Green's 1st identity:
\int_{\Omega} v \nabla^2 u \;+\; \nabla u \;\cdot \; \nabla v \; dx\;dy \;=\; \int_{\Gamma} v\frac{\partial u}{\partial n} \; ds
v=1 \;\Rightarrow\; \int_{\Omega} \nabla^2 u \; dx\;dy \;=\; \int_{\Gamma} \frac{\partial u}{\partial n} \; ds = 0 \;\hbox { if } \;u \;\hbox{ is a harmonic function .}
Why is it equal zero if u is harmonic function? Why is:
\int_{\Omega} \nabla^2 u \; dx\;dy =0 \hbox { if } \nabla^2 u =0
Or more basic question:
What is \int_{\Gamma} 0 dxdy? Is it not zero?
The integral of zero is zero. I don't see a problem here.
Thanks
So you mean:
\int_{\Omega} \nabla^2 u \; dx\;dy =0 \hbox { if } \nabla^2 u =0?
yungman said:
Thanks
So you mean:
Youngman, I don't want to get over my head with this or nothing, but let me try to explain since I jumped in: if the function u is harmonic, then the Laplacian is zero, not a limit which approaches zero but identically zero and surely the integral of zero is just zero.
I was just thinking if you differentiate x twice you get zero, if integration is the reverse of differentiation, should integrating zero be something! I dug up books and I did not see anything about this, that's why I posted.
Thanks for the help.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
