Grounding chasis in the electric vehicle
Grounding both the 12V low voltage system and the 144V high voltage system to a common ground in an electric vehicle can lead to significant electrical issues. If the ground is genuine, both systems will be effectively grounded; however, if it is not, the common ground rail will serve merely as a reference voltage for both systems. The outcome heavily relies on the specific wiring configuration of the vehicle, and creating a circuit diagram can clarify potential issues.
  • Understanding of electrical grounding principles
  • Familiarity with low voltage (12V) and high voltage (144V) systems in electric vehicles
  • Basic knowledge of circuit diagram creation
  • Experience with automotive electrical systems
  • Research the implications of grounding in hybrid and electric vehicle systems
  • Learn about circuit diagramming tools for automotive applications
  • Investigate the effects of improper grounding on vehicle electronics
  • Explore best practices for wiring high voltage systems in electric vehicles
Electrical engineers, automotive technicians, and anyone involved in the design or maintenance of electric vehicle systems.
nikita
what will happen if I ground my 12v(low voltage system) and 144v(high voltage system) to a common ground?
If it is a genuine ground - then they will both be grounded.
If not then the common "ground" rail acts as a reference voltage for both low and high voltage systems.
A lot will depend on how your car is wired though. You can probably sketch out the resulting circuit diagram.
  • · Replies 28 ·
  • · Replies 32 ·
